inVision Posted March 27, 2005 Share Posted March 27, 2005 Private auction. email me before bidding. [email protected]. http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=4539370412&rd=1&sspagename=STRK%3AMESE%3AIT&rd=1 in case that doesn't work it's item# 4539370412 Auction starts at 7pm Sunday but here is the text from the listing: This is the text from the listing: Starting bid: 30,995 This is a low mileage, excellent condition, track ready car - that has only been to the track 2x's. This car is hungry for more track time. interior: - 6 point chromoly cage custom built, painted performance red. - 4 point Crow harnesses (5 point capable). - MOMO pedals, with adjusted gas pedal (throttle cable) for optimum heal-toe. - additional phantom gauges mounted in empty compartment in dash (air/fuel, rear diff temp) w/carbon fiber face plate. - custom rear compartment made of honeycomb composite w/Hawker SBS 40 racing battery (stock battery included). performance: - Torsen T2R rear diff - stock included. - 03 Cobra half shafts - stock included. - 03 Cobra IRS brace - stock included. - 3.73 FRPP gears. - RACE systems 4 position chip. - Bassani high flow exhaust including high flow cats. - Kenny Brown rear diff cooler mounted in trunk with air ducted from cut out side vents and exiting cut out rear bumper vents. - MM poly suspension bushings, front and rear. - KB extreme matrix subframe connectors with jacking rails. - Steeda front bump steer with X2 ball joints. - Steeda rear steer kit. - replaced incorrect rear suspension bolts. - Borgensen solid steering shaft. - MM aluminum rack bushings, custom modified for tighter fit. - Functional hood louvres reinforced w/ carbon fiber. - Front splitter reinforced w/ carbon fiber, jab rock attached to bottom. - Front fascia reinforced with aluminum rods welded to frame. - Custom air intake. - KB front strut tower brace. miscellaneous: - Barely used front rotors - stock included. - Hawk HP+ pads - stock pads included. - 2 brand new, spare KD tires on OEM wheels, L & R. - Mobil 1 15-50 every 6 months. - Redline gear oil. - Radiator flushed every 3 months - 100% distilled water / watter wetter mix (we never get that cold here). - Carcoon encapsulated car storage with ventilation fans and - battery charger (over $600 value). - California car cover 100% flannel. - Several coats of Zaino, winner of HB Concours d'Elegance (if that means anything) and several other shows. All fabrication and installation done to highest quality specifications by Landmark Motorsport / Hybrid Racing. http://www.hybridracing.net YOU MUST EMAIL ME at [email protected] for further info before bidding on this car. If you bid before contacting me it will be removed. Carfax and more pics available upon request. Quote Link to comment Share on other sites More sharing options...
