snapturn Posted August 24, 2011 Share Posted August 24, 2011 FS H4 spec 92 Civic Si 92 Honda Civic Si Hatchback (Black) California Registered (Able to pass Smog Test) Salvaged Title (Stolen Recovery) No Accidents D16Z6 Race Built and Tuned Shaved Head Port and polished New Lower Beraings Pinned Vtech Redline Oil Neuspeed Header Custom 2.5” Exhaust Removeable Hi-Flow Catalytic Converter Adjustable Fuel Pressure Regulator Fuel Pressure Gauge Hondata S200 ECU AutoMeter Sport Comp Monster Tach Adjustable with Shift Light Oil Pressure, Oil Temp, and Water Temp Gauge Mocal Oil Cooler In-line Thermostatic Plate Allows automatic bypass of oil cooler when not racing Acura Radiator (oversized) Power Steering AEM Short Ram Intake (Dryflow) heater core intact and works Calculated Risk Roll Cage (Mike Lock design and build) Nascar Bars (Left Side) Diagonal Bar (Right Side) Recaro Schale Proracer XL SPG Racing Seat Schroth Profi III-6 Belts Momo Start Racing Seat (Passenger) Crowe Belts Koni Revalved Race Shocks Ground Control Coilovers Ground Control Springs (700/800/900) Adjustable Front and Rear Camber Acura Rear Trailing Arms Comptech Adjustable Rear Sway Bar Stock OEM Sway Bar Neuspeed Front Lower and Upper Tie Bar Poly Suspension Bushings Rebuilt Tranny KAZ Limited Slip Differential Short Throw Shifter ACT Heavy Duty Clutch Cobalt Friction Pads XR3 Braided Brake Lines Reinforced Front Bumper Extra bumper with light hookup for Enduros Kill Switch Momo Steering Wheel with Quick Release Fire Extinguisher Removeable Plexiglass Door Windows Hood Pins (12) Rota Slipstreams 7x15 (4x100) 40 Offset Quantity 12 (3 complete sets) Toyo RA1 205/50/15 Quantity 8 (used) (4) Falken ZE512 mounted on steel wheels (14") Longacre Hot Lap Timing System (Transmitter/Receiver) Tyvek Custom Fit Car Cover White Window Net Spare parts and fluids Make Offer Car Location Sacramento, CA Contact: [email protected] Derek Ramsey Pictures available at: http://ramseyderek.smugmug.com/Other/Honda-Civic-Si-Hatch-92/17092264_FXMsxK Specific pictures available upon request Quote Link to comment Share on other sites More sharing options...
