cool hand luke Posted October 31, 2011 Share Posted October 31, 2011 I'm looking on page 11 of the rulebook, for tire HP/weight ratio modifications and am a bit confused. If I'm running a less than 9.5" non dot approved tire, what is the adjustment for this? The very first line says Non DOT approved is -.75 Then the next 2 lines brake it down by size, saying 10.5-9.6 is +.4, while <9.6 is +.8 So would this tire combo be a total of +.05? I guess I don't know why there is the first line of -.75 that is not factored into the size categories. Seems redundant and confusing. Quote Link to comment Share on other sites More sharing options...
kbrew8991 Posted October 31, 2011 Share Posted October 31, 2011 It's separated out for a reason, so that non-dot narrow/wide/normal and dot approved narrow/wide/normal aren't the same correction factors but instead offers 6 different combinations. It is assumed you'll be running on a good, fresh Non-DOT slick which would be faster than a good, fresh DOT approved counterpart. It also assumes that the wider tire will be faster than the narrower tire and accounts for each of those accordingly. a 9.5" or narrower slick (non-dot) would be -0.75 and +0.8 for a net of +0.05. the Excel tool that was built makes doing these calculations easier, as well as illustrating some of the concepts just by clicking different combinations of the various correction factor boxes Quote Link to comment Share on other sites More sharing options...
cool hand luke Posted October 31, 2011 Author Share Posted October 31, 2011 so what it's saying is Non DOT > 10.5 = -.75 Non DOT <10.5 and > 9.5 = -.35 Non DOT <9.5 = +.05 Looks like I'm hitting the ballast. I can't find an excel sheet newer than 2009, anyone know where it is? Quote Link to comment Share on other sites More sharing options...
kbrew8991 Posted October 31, 2011 Share Posted October 31, 2011 try here: viewtopic.php?f=2&t=39367 Quote Link to comment Share on other sites More sharing options...
