johnalley Posted December 24, 2011 Share Posted December 24, 2011 I am planning on movig to ST-2 in 2012 and have a question I can't seem to find an answer for. Does the battery disconnect switch need to be external to the engine compartment or can it be under the hood? Quote Link to comment Share on other sites More sharing options...
kbrew8991 Posted December 24, 2011 Share Posted December 24, 2011 from the CCRs: 15.8 Master SwitchAn electrical master switch is recommended on all cars, and required on some, as listed in the class rules. It shall be mounted so that it is easily accessible from the outside. If mounted outside the cockpit, it should be mounted in an area where it is least likely to be damage (e.g. cowling near wipers). The switch shall shut off the motor and cut all power except to the on-board fire system and any other life support / medical device. The switch location must be clearly marked. Any marked switch must function as per this rule, or the indication decal must be removed. so if the ST/SU ruleset requires the switch, it must be accessible from the outside of the car by a cornerworker - right inside a window opening is probably the "least" accessible area I've seen that passed. Quote Link to comment Share on other sites More sharing options...
johnalley Posted December 24, 2011 Author Share Posted December 24, 2011 from the CCRs:15.8 Master SwitchAn electrical master switch is recommended on all cars, and required on some, as listed in the class rules. It shall be mounted so that it is easily accessible from the outside. If mounted outside the cockpit, it should be mounted in an area where it is least likely to be damage (e.g. cowling near wipers). The switch shall shut off the motor and cut all power except to the on-board fire system and any other life support / medical device. The switch location must be clearly marked. Any marked switch must function as per this rule, or the indication decal must be removed. so if the ST/SU ruleset requires the switch, it must be accessible from the outside of the car by a cornerworker - right inside a window opening is probably the "least" accessible area I've seen that passed. Thanks for the info. I missed that when I was reading the CCR. It does say in the ST rules that a switch is required. Quote Link to comment Share on other sites More sharing options...
kbrew8991 Posted December 26, 2011 Share Posted December 26, 2011 no worries, everyone ends up overlooking something at some point Quote Link to comment Share on other sites More sharing options...
Cobra4B Posted December 26, 2011 Share Posted December 26, 2011 Carlos at Autodynamix put mine on the driver's side A-pillar so it could be easily reached by me or a corner worker. Quote Link to comment Share on other sites More sharing options...
Balroks Posted December 27, 2011 Share Posted December 27, 2011 ^ Ditto. Lots of reasons to have this or that but safest place in my opinion for our level. Quote Link to comment Share on other sites More sharing options...
