tkarttrev Posted April 28, 2005 Share Posted April 28, 2005 As Seen on CMC Forum: For Sale: 1996 Camaro SS endurance racecar Built for Speed World Chalenge and converted to Grand Am Cup specs, this car ran 2002 and 2003 in the GS2 class of Grand Am Cup with strong results (Qualified 3rd at VIR and Daytona 2003) The car is very clean and is turn key. Below is a link to a full spec sheet with extensive pictures of the car. The Camaro is in Essex, CT There are just too many features to the car to list here. http://www.tkartsusa.com/camaro.html Asking $25,000 with spares included. Fuel rig available [email protected] Specs for the car shown below and at the link above: 1996 Chevrolet Camaro SS Racecar Weight: 3100lbs dry Engine: Chevrolet LT1 V8 engine prepared to Grand Am Cup rules. Cast iron block Aluminum cylinder heads GM Motorsports "Hot" cam package including GM "Hot" cam GM roller hydraulic lifters GM Roller rockers GM adjustable rocker studs Ferrea valves Balanced and Blueprinted Under-drive Pulleys Hooker Super Comp Header, silver ceramic coated Doctor Gas X-pipe and NASCAR style "Boom Tubes" GM factory lightweight flywheel GM stock clutch assembly Canton road race oil pan Griffin Aluminum radiator / power steering cooler / oil cooler Lightweight GM alternator SS ram-air intake with K&N filter GM non-street legal Fuel Injection GM non-street legal Fuel Injection mapping in ECM Engine Performance: 430 Horsepower 6500 RPM rev limit Less than 20 hours of running time. Transmission and Rear End: Borg-Warner/Tremec T56 6-speed + Reverse Heavy Duty shift forks and sliders Overdrive 5th and 6th gear Aluminum driveshaft, high speed balanced GM rear axle housing Auburn 3.41:1 limited slip differential Mosier racing axles Axle housing modified for proper toe and camber Aluminum differential cover with temp sender and bearing supports Diff. Oil baffles Brakes: Willwood 6-Piston front Calipers, aluminum Willwood vented rotors, 9.5" id X 13" od X 1-13/16" thickness, Cryotreated (doubles life, improves pedal feel) Custom aluminum rotor hats, front Stainless steel braided brake lines, front and rear Quick Disconect /Dry Break brake lines, rear GM aluminum calipers, rear GM stock steel rotors, rear Willwood proportioning valve Willwood and PFC brake pads Extensive cooling ducts and hoses for front brakes GM power brake booster Suspension, Wheels and Tires: Penske 8100 dampers with remote reservoirs, adjustable bump and rebound, bump rubbers, custom valving Eibach, Hyperco and GM springs Tubular front sway bar, adjustable, spherical bearings on links Blade type adjustable rear sway bar, can be cockpit adjusted with proper cable Spherical and Urethane bushings throughout GM rack-and-pinion steering, power steering pump GM spindles and A-arms Custom camber/castor adjusters Modified front Sub-Frame Coleman steel front hubs with adjustable tapered bearings. 17" X 10.5" 3-Piece CCW aluminum wheels Hoosier 275-45-17 GAC Tires (DOT racing tire) Chassis: 1996 Chevrolet Camaro chassis Welded 7-point 4130 chro-mo steel roll cage with door bars Fully stripped of all interior, trim and insulation Stock dash board with heater/defrost Auto Meter gauges including: Tachometer Oil Pressure Oil Temperature Water Temperature Volt Meter Differential Temperature Fuel Pressure Shift Light, adjustable Kirkey Enduro aluminum seat, CNC lightened endurance seat with cover Schroth HANS style 6-point harness Leather covered racing steering wheel Full width rear-view mirror Cockpit fire system, new, cable type, 5lbs Engine fire system, new, cable type, 5lbs 22 gallon ATL fuel cell with internal pump, fuel cell foam, adjustable pickup, quick fill Stock plastic front fenders, doors and read deck lid, stock glass Lightweight Ram-Air SS hood, fiberglass with hood pins Heat shielding on underside of chassis Painless-brand lightweight wiring harness Stock Windshield wiper system Black interior General Description and Racing History: This car was purchased new and built to Speed World Challenge rules where it competed for 1 year. The car was then converted to Grand Am Cup (GAC) rules and campaigned in the 2002 and 2003 GAC series. The GAC series is an endurance series for "street-stock" cars. All vehicles retain stock bodywork and a relatively "stock" chassis and drivetrain. Races are between 3- and 6-hours with pit stops and driver changes. The Camaro competed against Porsche GT3, BMW M3, Nissan 350Z, Audi S4, Ford Mustang Cobra, Pontiac Firebird, Acura NSX and similar cars. Built for endurance, the car is very durable and very low maintenance. The car starts and runs and drives smoothly, like a road car. Clutch and shifting action are very smooth, gear changes are quick and easy. Steering feel is light thanks to the power steering and the car gives good feedback. Drivers regularly did double stints in the car (2 hours) without excessive fatigue. Braking effort is light and pedal feel is good. Tire life is excellent using the Hoosier spec GAC tire, typical tire life is 15 min qualifying + 1 to 2 hours in race + 1 to 2 hours of testing per set. Brake Pads and rotors will typically last for 6 hours of track time (1.5 to 2 GAC weekends) Cryo-treating the rotors ($90/set) doubles the rotor life and improves pedal feel. In 8 GAC races, the car qualified 3rd on the grid twice (out of 20+ cars) at Virginia International and Daytona (both 2004) Best finish was a 5th place (Daytona 2003 6-hour) after running 2nd in the 5th hour. Top speed at Daytona was 168 MPH. The car was built for GAC by Precision Motor Werks of Marblehead MA, USA, where all engine and chassis work was performed. The car has had two light crashes, and was repaired to like-new condition by Precision Motor Werks. There is little evidence of repairs. The car does not have a DMV title. Spares Included: Six (6) 17" X 10.5" CCW 3-Piece wheels in excellent condition with good low-miles Hoosier GAC tires mounted. 1 Set of Willwood Brake Pads, New Front 1 Rear Sway Bar 1 Front Sway Bar 2 sets of new front wheel bearings Power steering pump Motor and trans mounts (2 complete sets) Strut top mounts (2) Oil Filters Wheel Studs and nuts 2 New Willwood front rotors, with alum hats, cryotreated 2 spare alum hats, 1 spare used rotor 4 used rear calipers with mounting plates 1 pan hard rod 1 drive shaft 1 complete rear axle assembly with: alum diff cover, calipers, Auburn diff, rotors, quick disconnect brake lines. 2 spare front A-Arms 2 spare spindles, front 1 set (4) Koni adjustable shocks, recently rebuilt 1 spare Griffin race radiator (used but good), 1 spare stock radiator Clutch assembly 7 sets of various rate springs Spare for every ball-joint and bushing on car 2 rear axles Gaskets and Seals Spares Available for added cost: Complete LT1 spare race engine available Auburn and Dana 44 differentials 1 piece 17" x 10" 5-spoke wheels, mounted full tread rain tires, Hoosier Complete Grand Am style gravity feed refueling rig with hose and dry break fittings As Sold by Trevor Hilliar, [email protected] 860-767-5012 Quote Link to comment Share on other sites More sharing options...
pederb Posted May 4, 2005 Share Posted May 4, 2005 I did not read the whole ad but is the firewall intact or moved like most WC cars? Quote Link to comment Share on other sites More sharing options...
racercosmo Posted May 4, 2005 Share Posted May 4, 2005 It ran Grand-Am Cup, so it's probably intact. I don't know where the firewall being moved in World Challenge cars came from. I have seen few cars with the firewall modified. Quote Link to comment Share on other sites More sharing options...
pederb Posted May 5, 2005 Share Posted May 5, 2005 All the Saleen SR's I have seen plus JR's Camaro and don't forget Carol's car Quote Link to comment Share on other sites More sharing options...
tkarttrev Posted May 6, 2005 Author Share Posted May 6, 2005 Thanks for the inquiry. The firewall is in its stock location and configuration. Trevor Quote Link to comment Share on other sites More sharing options...
tkarttrev Posted July 28, 2005 Author Share Posted July 28, 2005 The Camaro is currently for sale on EBAY with a $16k starting bid and no reserve. Happy bidding. Trev http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=4564848403 Quote Link to comment Share on other sites More sharing options...
