condor Posted March 12, 2012 Share Posted March 12, 2012 1988 Condor Speed Shop Widebody BMW 325IS TURBO Perfect car for Track Days, TT, or Time Attack. Will trade for an SE30 The car started as a Grassroots Motorsports Challenge car. It has been a participant in 4 GRM Challenges and finished 3rd overall for the last 2, and 2nd in autoX both years. The car was then invited to participate in the Ultimate Track Car Challenge at VIR in 2011, and finished 4th fastest in group B. Due to the nature of the build, the car has received quite a bit of recognition. This includes a cover shot for GRM magazine as well as several other articles throughout the cars history. The most recent write up was an 8 page spread in Performance BMW Magazine, based out of the UK. The car was tuned by DIY Autotune, 356 RWHP at 15psi. Its reliable and FAST. NEW parts installed in preparation for the Ultimate Track Car Challenge (within the last year): Engine OEM Thermostat & Water Pump and ALL coolant hoses All new gaskets & seals ARP head studs Timing belt and Tensioner Crank Scraper Cometic Metal Headgasket Turner Motorsport Performance Plug wires, OEM Distributor, rotor, & cap. Motor mount reinforcement kit, fan delete bolt, Redline transmission, & differential fluid. SPAL Electric Fan, Puller, 16 in. Diameter, 3.39 in. Thick, 2,070 cfm, Holset Twin-scroll HX35 Stainless-steel "M12x1.5 Turbo Oil Feed Line 36"" Silicone couplers & T-bolt clamps Walbro Fuel Pump 255LPH T3 / T4 PTP Turbo Blanket(Item # 300374057741) ACCEL SPARK PLUG WIRE INSULATORS "Black ""TREATED"" 2"" x 20 ' Exhaust Header Wrap by NRM Suspension Turner Motorsport Stainless steel brake lines, stainless steel clutch line. New Tie-rods e30 m3 sway bar end links w/E30 Convertible swaybar Ground Control Complete Coilover Suspension including camber plates, rear solid top mounts & front e30 M3 strut housings New Front wheel bearings Custom valved bilstein shocks & Eibach Springs front & rear HT10 brake pads ETL Blue Brake fluid All 4 calipers Rebuilt New front OEM rotors Interior Push button start Autometer Water Temp Gauge Autometer Oil Pressure Gauge w/Stainless Steel oil pressure line and T fitting Adapter AEM Wideband Gauge AEM True Boost Gauge DIY Autotune PNP Megasquirt Dynotuned by DIY Autotune G-Force 5 pt Camlock Harness & mounting Hardware Custom Harness Bar Chassis 1 of only 3 custom fiberglass front bumpers mounted with Dzus Self Ejecting Fasteners 16x10 Diamond Racing wheels 20mm front wheel spacers wheel studs 8x Black Zinc 75mm, 8x 44mm & full set of Black Zinc 17mm Nuts Goodyear Race Slicks 23.5 x 10.5 x 16 Parts pre-UTCC Engine: 2.7l block with a mildly ported 885 Head. Ported 524TD Exhaust Manifold Custom dual chamber T3 spacer with External waste-gate & dump tube. Ported OEM Intake Manifold 36lb INJECTORS Lightened Flywheel with Sachs Heavy Duty Pressure plate & 4 puck clutch. OEM Clutch master OEM Brake Master OEM slave cylinder Custom exhaust and intercooler piping Front Mount Intercooler. Suspension 325IC Front Swaybar Polyurethane front Swaybar mounts Solid UHMW Motor Mounts, Transmission Mounts, & Rear Subframe Mounts Toe and camber correction bolts in the rear. Solid UHMW rear subframe mounts Powersteering delete Chassis 5th lightest e30 on the planet at 2160 lbs Full custom Widebody made from OEM metal BMW panels. Gutted hood, trunk & doors Removed sunroof & cartridge Removed all unnecessary wiring Lexan door(removable), quarter & Rear windows Plexi sunroof cover. Completely tucked engine and chassis wiring harness Kirkey Race seat on custom factory sliders Great condition Dash Carbon Gauge panel $11,500 obo, please serious inquiry's only! If you have any questions please feel free to contact me at [email protected]. PHOTOS VIDEOS Photos BUILD BLOG http://www.dirte30.blogspot.com Quote Link to comment Share on other sites More sharing options...
getfast Posted March 14, 2012 Share Posted March 14, 2012 Love this car, best of luck with the sale. Trade for a human kidney in decent condition? Quote Link to comment Share on other sites More sharing options...
SpeedWorksRacing Posted March 14, 2012 Share Posted March 14, 2012 That kidney is not in decent condition. Good luck with the sale man, I can assure that whoever buys this is going to be very happy. This thing is one of the coolest E30's I've ever seen. Quote Link to comment Share on other sites More sharing options...
Rob S. Posted March 16, 2012 Share Posted March 16, 2012 What's the TT/ST ratio Mod Factor for the exhaust going through the hood? Quote Link to comment Share on other sites More sharing options...
ILIKETODRIVE Posted March 16, 2012 Share Posted March 16, 2012 What's the TT/ST ratio Mod Factor for the exhaust going through the hood? Infinity...? Quote Link to comment Share on other sites More sharing options...
TrackRat Posted March 20, 2012 Share Posted March 20, 2012 Come on, someone needs to give this amazing car a home! Quote Link to comment Share on other sites More sharing options...
TurboShortBus Posted March 22, 2012 Share Posted March 22, 2012 I'll give you $2012 for it (adjusted for inflation). Mark Quote Link to comment Share on other sites More sharing options...
aaronsti Posted March 23, 2012 Share Posted March 23, 2012 how is a 2000 dollar car going for 11500 Quote Link to comment Share on other sites More sharing options...
kbrew8991 Posted March 23, 2012 Share Posted March 23, 2012 2,000 in raw materials + sweat equity and fabrication Quote Link to comment Share on other sites More sharing options...
TrackRat Posted March 26, 2012 Share Posted March 26, 2012 how is a 2000 dollar car going for 11500 It's not a $2K car folks. It was a GRM Challenge car, then was an Ultimate Track Car Challenge - lots of new parts/work/etc was put into it. I have seen this car run several times, it's incredible. Amazing power and super light. Free bump for a cool seller and great car! Someone give it a good home! Quote Link to comment Share on other sites More sharing options...
sscguy Posted March 29, 2012 Share Posted March 29, 2012 Interesting. I read the most recent issue of GRM with the rat-rod version of this for the 2011 Challenge winner, and wondered how much a better, non-Challenge version would go for. Not a bad price, really Out of my range, by, oh $11K, but good to know for the future. Good luck with the sale! Quote Link to comment Share on other sites More sharing options...
Fair Posted May 17, 2012 Share Posted May 17, 2012 Very clean car that is well worth the asking price, if not more! You have to ignore the whole "GRM $20xx" budget numbers, as that doesn't include a lot of safety gear or the hundreds if not thousands of hours of labor involved with making every little part to meet the rules for that competition. Not to mention that they've added thousands in parts and work after they took it beyond the GRM Challenge rules. Great price on a sweet car! Quote Link to comment Share on other sites More sharing options...
Karl Posted May 18, 2012 Share Posted May 18, 2012 if only you spelled it Kondor than I would have to buy it, to protect the name. Very cool car, I wish I could own it. Quote Link to comment Share on other sites More sharing options...
