dcazin Posted April 27, 2012 Share Posted April 27, 2012 since this is my first Z... I have found a million posts regarding Yaw Sensor bypass - switchable. With that in mind, if they are simply bypassing power to the sensor for a temporary time - would a complete removal of the Bosh unit, provide a permanent benefit or does this control ABS in some fashion. I thought I was going to die when braking into a corner @ 90+ the other day, with VDC disabled.... totally forgot about the secondary unit. Has anyone removed the Bosch unit, without issues? thanks! Quote Link to comment Share on other sites More sharing options...
laze1 Posted April 30, 2012 Share Posted April 30, 2012 This how I did it when I tracked my DD disconnect the battery lift up the center console disconnect the wiring harness from the yaw sensor (positioned just behind the shifter) NOT the AirBag sensor at the back end of the console area reconnect the battery drive it like you stole it disconnect the battery reconnect the yaw sensor for the drive home reconnect the battery repeat as necessary For the race car; I have completed removed the yaw sensor...ABS works fine...just no nasty VDC problems...but have several lights lite on the dash... Quote Link to comment Share on other sites More sharing options...
dcazin Posted May 11, 2012 Author Share Posted May 11, 2012 This how I did it when I tracked my DD disconnect the battery lift up the center console disconnect the wiring harness from the yaw sensor (positioned just behind the shifter) NOT the AirBag sensor at the back end of the console area reconnect the battery drive it like you stole it disconnect the battery reconnect the yaw sensor for the drive home reconnect the battery repeat as necessary For the race car; I have completed removed the yaw sensor...ABS works fine...just no nasty VDC problems...but have several lights lite on the dash... I tracked mine last weekend - just simply disconnected the bosch sensor -- absolutely no issues -- remains disconnected and will never go back. Black duct tape over the dash lights will make you forget they are on!! Quote Link to comment Share on other sites More sharing options...
