dcazin Posted June 11, 2012 Share Posted June 11, 2012 OK, so, I went to shop for the appropriate bushings, per the rules: NISMO Hard Rubber Suspension Bushings 54541-RRZ30 Front upper A arm bushing 4 54560-RRZ30 Front lower transverse link bushing 2 55045-RRZ30 Rear upper A arm bushing 4 55148-RRZ30 Rear radius rod (toe link) at hub bushing 2 55149-RRZ30 Rear radius rod (toe link) at body bushing 2 55152-RRZ30 Rear lower link (camber link) at hub bushing 2 55153-RRZ30 Rear lower link (camber link) at body bushing 2 55158-RRZ30 Rear lower control arm (spring arm) bushing 2 56218-RRZ30 Rear upper shock absorber bushing 2 These are no longer available : 55149-RRZ30 Rear radius rod (toe link) at body bushing 2 These are on backorder with no ETA: 54541-RRZ30 Front upper A arm bushing 4 & 56218-RRZ30 Rear upper shock absorber bushing 2 also, pricing seems a bit jacked just for bushings - for what's available, it's 500+ dollars.... SO - where did you get yours and was it in the 500.00 range? thanks! Quote Link to comment Share on other sites More sharing options...
laze1 Posted June 12, 2012 Share Posted June 12, 2012 I am all stock OEM bushings... Quote Link to comment Share on other sites More sharing options...
scotts300 Posted June 12, 2012 Share Posted June 12, 2012 I am all stock OEM bushings... Me too. Already ~$20k in on each build, so holding off on another $1k for bushings while my feet get wet. Quote Link to comment Share on other sites More sharing options...
