slickS14 Posted May 30, 2005 Share Posted May 30, 2005 FOR SALE - 1995 Nissan 240sx ITS Racecar (S14 no-sunroof,no ABS car) Fully developed, race ready, currently competing in SCCA ITS SARRC series and occasional ECR series races. Just a few specs listed, please call for details. Easily meets SCCA minimum weight of 2650# w/ driver Pics of the car can be seen at http://www.newberryracing.com Professionally built fully welded cage with drivers side nascar bars Kirkey deluxe Aluminum road race seat mounted to integral seat box New G-Force belts - FIA rated for 5 years Simpson window net Ultra Lite Autometer guages in professional guage panel inserts Moroso switch panel with circuit breakers, Cut Off switch Maximum .020 ITS legal Robbie Chastain KA24DE engine - 3 races new Jim Wolf custom Dyno tuned ECU Flowed and matched fuel injectors Race prepped transmission - freshened also 3 races new NISMO LSD and 4.62 NISMO gear - 1 year old - always RED LINE oil in it Dyno Tuned mandrel bent custom exhaust system All spherical bearing F&R suspension and aluminum sub frame bushings Ground Control coil overs, Eibach Springs, Koni Yellow adjustable shocks Camber / Caster plates, rear upper shock mounts solid with sphericals Custom RRE Front NASCAR style sway bar with adjustable heim joints Custom RRE welded aluminum upper strut bar with adjustable Heim joints NISMO steering rack bushings, MOOG HD outer tie rod ends Hawk brakes and steel braided brake lines, front brake ducts, AP600 fluid 1/2" ARP racing wheel studs SPEC clutch and steel braided clutch line Custom Griffin aluminum radiator with oil cooler built in, all AN -10 lines 5 Panel racing wink mirror Removable steering wheel K&N air filter The car is very balanced, easy to drive and fast. Very rarely out of top 5 SCCA races in southeast and only 2 mechanical DNF's in 2.5 seasons. (due to broken faulty Moroso wheel studs, since all replaced with ARP) No major incidents or ever any chassis damage. Asking $12,500 for car and $2500 for spares minus spare motor - That's extra but a package can be put together for a serious buyer (not from over seas with BS money orders) Terms of sale - US CASH ONLY!! You will not run in the front for less and can't build this car for double. Thanks for looking, please call Chris Newberry at 404-314-5042 if interested. The car is located in Atlanta GA and pick up arrangements can be made at time of sale, I'm flexible but not hauling it to California or Zimbabwe. Quote Link to comment Share on other sites More sharing options...
slickS14 Posted June 1, 2005 Author Share Posted June 1, 2005 I can have this car at Road Atlanta this weekend for the Double Pro-IT if anyone is interested in seeing it or renting it. Thanks, Chris Quote Link to comment Share on other sites More sharing options...
