Bruce Peter Posted June 6, 2005 Share Posted June 6, 2005 Hi folks. I have a question about my current net mount. I use the seat bealt type mount in the front. In the rear I simply drilled a hole in the vertcal style of my cage. Will this pass tech for AIX? Or do I need the proper mount? Thank you Bruce Quote Link to comment Share on other sites More sharing options...
trackboss Posted June 7, 2005 Share Posted June 7, 2005 You need to weld a tab for the rear of the rod to fit into. I don't think drilling into the cage will pass. Even if it did I would never recommend that. All window kits I have used come with a tab for the rear. They are simple and can be easily made yourself as well. -V Quote Link to comment Share on other sites More sharing options...
