NASA Admin Posted April 10, 2003 Share Posted April 10, 2003 To register for an event, you first need to login. To register for an event, you must have a valid NASA membership. If you do not have a current NASA membership, one will be added automatically to your shopping card when you check out. If you get an error that your cart is empty, one of three things is happening: 1. You did not log in. 2. You do not have cookies enabled. Cookies are required to complete the purchase process. 3. You did not select box the checkbox next to the group and the class from the drop down. You much check the box next to the item you want and select a class. Quote Link to comment Share on other sites More sharing options...
NASA Admin Posted April 10, 2003 Author Share Posted April 10, 2003 If you are signing up for an event and you have a valid membership, but it keeps getting added to your shopping cart then one of two things has happened: 1. Your membership has expired. 2. There is not a valid membership on this account. This is usually caused by creating a second account that does not have membership info. Always sign up for an event using the account you used to buy your membership. Otherwise we won't know you're a member! Quote Link to comment Share on other sites More sharing options...
