Ivan Orisek Posted June 28, 2005 Share Posted June 28, 2005 Edited for sold items Audi Parts for Sale Ivan Orisek 845-794-4096 [email protected] http://www.hometown.aol.com/EURORALLY -APEX electronic boost controller -KKK Lehman turbocharger (Group A) -Two stock Audi 5000 turbochargers -Matching downpipe with modified wastegate with a choice of springs -Schrick 272deg./268 deg. camshaft -Modified, ported 10-valve cylinder head with front to back coolant flow, complete with oFuel rail with modified Mitsubishi 780 cc electronic fuel injectors good for 600 HP with a new spare injector injecting, directly over intake valves oFabricated aluminum 2 ½ inch throttle body oIntake manifold with matched ports oExhaust manifold with matched ports -Complete working 2.3 liter engine bottom with oForged aluminum JE pistons oPauter chromemoly connecting rods oTotal Seal piston rings oFloating wrist pins oBaffled oil pan o240 mm flywheel and clutch -Front dual oil cooler setup with Mocal racing thermostat -Aluminum racing radiator (fits stock mounting points) -Large Spearco racing intercooler (core 22 x 15 x 3 ½ inches) -150 Amps Bosch racing alternator from Audi Sport -Two electronic distributors without vacuum advance -Water injection setup injecting into throttle body -Five 15 inch Fuchs wheels -Four used Michelin C3 (narrow) snow tires -Complete fabricated front and rear suspension including oMacPherson fabricated struts with hubs, lower ball joints and adjustable camber and caster oGirling brake calipers with several sets of Porterfield carbon Kevlar racing pads (two pistons in front, one piston in rear) oBilstein racing shocks with digressive valving oEibach progressive springs on adjustable perches oTubular lower control arms with wide track with matching axles of proper length oSet of aluminum bushings for the front subframe Quote Link to comment Share on other sites More sharing options...
