Elvenhome21 Posted March 17, 2013 Share Posted March 17, 2013 Its getting close to racing season and Im getting sick of the POS trailer Ive been using for the last couple years. So Im looking at building another one. My dad and I already have built a nice superlite car trailer but its not wide enough, has rigid suspension, and its not meant to haul anything more then about 3k lb car. The new one is going to be a 7k-10k trailer Id love to justify the price of a maxey drop and load but I know I can build it for well less than half and fit my needs better. But overall I will be copying a lot of the ideas for the new trailer (air ride, no ramp loading) http://www.maxeytrailers.com/trailer-details.php?tid=124 I can even make the axle-less air ride with my cnc plasma cutter. Its a fairly straight forward design http://www.etrailer.com/Trailer-Suspension/Timbren/A35RD545E.html One thing Im not sure about is what coupler I want. Ive seen a couple people say use a bulldog, but after searching last night I found a Demco Ez Latch hitch that look pretty slick. Ive never used anything other then the plain flip style and the wrap around style which I despise with a passion. Any Suggestions? Im planning on it being 5x2" tubing frame or possibly 6x2 with a thinner wall. The main deck will be 20' long and deck width needs to be min of 84" i believe But ill prob just make the outside of the tires sit right at 102" for maximum deck space for easiest loading. Im figuring on spacing the axles apart from each other an extra 10-14 inchs apart from each other for a more stable riding trailer plus it should be less finicky on car placement if you have to load it backwards or something weird. I know it will have more scrub but i can either have a electric dump valve for the front axle for sharp turns or run a leveler valve with a slight difference between the front and rear axles to force the front axle to be the scrub axle with less weight on it. Havent decided yet if I want 6 or 8 bolt hubs yet. Any Suggestions? Quote Link to comment Share on other sites More sharing options...
