F430GTRad Posted June 13, 2013 Posted June 13, 2013 I'm debating with a NASA-TT driver in regards to interpretation of the NASA-TT rules. Appendix B “Adjusted Weight/Power Ratio” Calculation for TTB-TTF, establishes W/P ratio limits. My interpretation of the rules is the following: 1) For a given car, search for the car listed in the Base Classifications list. This list contains the base NASA-TT class for a car in Base Model Trim (BMT). If the car is not listed, contact the National TT director. 2) If a car has one (*) it takes 7 points penalty, a car listed with two (**) takes 14 points penalty 3) A car cannot exceed 19 modification points, otherwise it needs to be bumped to faster classes. The points in excess of 19 are carried over to the next class. 4) Once the car has reached a class based on points, the car also has to satisfy the weight/power limits of that class, otherwise it would get bump to faster classes, despite of having enough points to stay in a slower class. My interpretation is that a car has to satisfy both: the Points limit and also the Weight/Power ratio limit His/Their interpretation is the following: 1) Weight/Power ratio or Base Classification List establishes the base class. This means one or the other can be used 2) Then add points based on the modifications, and bump up classes using the points. An example: An Audi TT-225Hp. It is listed as a TTD car in the list. On my interpretation, the Audi-TT 225Hp will start at TTD and move up depending on modification points. On his/their interpretation, the same Audi would startw in TTF given a race weight (with fuel and driver) of 3,550 lbs that puts 180whp on a dyno. Which one is correct? Quote
ScottBell Posted June 13, 2013 Posted June 13, 2013 You are correct. The only way the base class of a car changes from the rules is if a dyno reclass is issued by the national director. That reclass will give you a new base class, weight and dyno HP limit. However, the adjusted P/W limits are an overriding rule. Even if a car is classed solely on points it still can not exceed the adjusted P/W for the class. Basically you can move up a class on P/W, but not down without an official reclass. Quote
kbrew8991 Posted June 13, 2013 Posted June 13, 2013 Your base class is tied to your listing or your official reclass email from Greg and *nothing else*. What are they smoking that they're seeing where you can just make up your own base class? The only reason the adjusted hp/weight stuff is even talked about in TTB-F is to put a cap on each class to keep everyone in the same rough ballpark. You have to be good on points AND hp/weight adjusted ratio Quote
ILIKETODRIVE Posted June 13, 2013 Posted June 13, 2013 The only reason the adjusted hp/weight stuff is even talked about in TTB-F is to put a cap on each class to keep everyone in the same rough ballpark. You have to be good on points AND hp/weight adjusted ratio Exactly. His interpretation is trying to apply this logic to the starting point of a vehicle when it only applies as a ceiling that each vehicle has to stay under for its class. Quote
TurboShortBus Posted June 14, 2013 Posted June 14, 2013 Hey Rad, I would like to know who your other NASA-TT driver is so that I can determine how much of his car will be disassembled in tech next time. Feel free to send me a private e-mail or throw him under the bus publicly. Good times! Mark Quote
Varkwso Posted June 14, 2013 Posted June 14, 2013 Hey Rad, I would like to know who your other NASA-TT driver is so that I can determine how much of his car will be disassembled in tech next time. Feel free to send me a private e-mail or throw him under the bus publicly. Good times! Mark Public flogging is good. Quote
BlkGt3 Posted June 14, 2013 Posted June 14, 2013 Hey Rad, I would like to know who your other NASA-TT driver is so that I can determine how much of his car will be disassembled in tech next time. Feel free to send me a private e-mail or throw him under the bus publicly. Good times! Mark Peter Quote
Varkwso Posted June 16, 2013 Posted June 16, 2013 Hey Rad, I would like to know who your other NASA-TT driver is so that I can determine how much of his car will be disassembled in tech next time. Feel free to send me a private e-mail or throw him under the bus publicly. Good times! Mark Peter Figures.... Quote
BlkGt3 Posted June 18, 2013 Posted June 18, 2013 Hey Rad, I would like to know who your other NASA-TT driver is so that I can determine how much of his car will be disassembled in tech next time. Feel free to send me a private e-mail or throw him under the bus publicly. Good times! Mark Peter Figures.... You of so little faith. Peter Quote
F430GTRad Posted June 19, 2013 Author Posted June 19, 2013 Apparently, I'm not 100% correct, based on the "confidential" West Coast NASA-TT driver. The Regional TT director can re-class a car down, based on weight/power ratio from what is listed in the rule book. So, a German TTD* or TTD** car goes down to TTD based on W/P ratio, then adds points based on modifications. I would let the "confidential" driver chime in, as he frequents these forums. Quote
kbrew8991 Posted June 19, 2013 Posted June 19, 2013 Regional cannot - National can. Still wrong. Quote
ILIKETODRIVE Posted June 19, 2013 Posted June 19, 2013 It's not super secret. We had a 1997 Acura Integra Type-R running in TTE (E** reclass, D base) years ago and he ran 205 RA1s (0 points [+7 compound -7 size]) Koni shocks (+3) and exhaust (+2). I killed his old record at the 2 tracks he had records at but basically he did it just to do it. Quote
CWeber Posted June 21, 2013 Posted June 21, 2013 ^ yup, downclassing by tire type and size is nothing new! (as was seen at Nationals when someone ran 185s... lol) Quote
Joshua Posted June 26, 2013 Posted June 26, 2013 Downsizing by tire is on the points-based system, and has nothing to do with re-assigning a base class based on W/P. Only the TT national director can do that. Quote
