68stang Posted June 26, 2013 Share Posted June 26, 2013 tire wear and longevity on Hoosier 225 -45 - ZR17? I have two sets . all 8 tires show the wear lines still.some scrubbing on outside edges. just wondering how long I can push these tire safely? 3000 pound car and generally 40 psi hot. thanks Bruce Quote Link to comment Share on other sites More sharing options...
kbrew8991 Posted June 26, 2013 Share Posted June 26, 2013 If you're not competeing or worrying about every last tenth, push them until you start to see signs of the first layer of nylon cord popping through. They won't be as fast as new, but... Quote Link to comment Share on other sites More sharing options...
getfast Posted June 26, 2013 Share Posted June 26, 2013 Which compound and how's your alignment? Quote Link to comment Share on other sites More sharing options...
Dizmm Posted June 26, 2013 Share Posted June 26, 2013 a 225 wide tire on a 3000lb car wont last too long. just make sure to inspect them prior to every session. Quote Link to comment Share on other sites More sharing options...
68stang Posted June 26, 2013 Author Share Posted June 26, 2013 thank you for the response next set of tires what size would you suggest for 3000 pound car.and to answer the other question R6 is the compound Quote Link to comment Share on other sites More sharing options...
68stang Posted June 26, 2013 Author Share Posted June 26, 2013 2 degree negative camber is all I can get out of the stang Quote Link to comment Share on other sites More sharing options...
Dizmm Posted June 27, 2013 Share Posted June 27, 2013 a 265 wide R6 would be more ideal for a 3000lb car. Quote Link to comment Share on other sites More sharing options...
clydesdale Posted June 28, 2013 Share Posted June 28, 2013 I run the same 225's on a 3200# subaru but with a lot more negative camber, around -3.5. I find that the outside shoulders are still where the wear is greatest and so I rotate the tires front and rear and I also reverse them on the wheel occasionally. I can usually use them for more than 6 weekends-- 12-16 races. However, the R6 loses speed after a few heat cycles and then loses even more speed after about 15-20 heat cycles. When doing TT that would translate into about 2-3 weekends before losing 2 seconds a lap. If you still show the circumferential grooves and the shoulder isn't down to the cord I'd say use them, just inspect after every session as Dizmm already said. Quote Link to comment Share on other sites More sharing options...
