matthewAPM Posted September 19, 2013 Posted September 19, 2013 Hello everyone, I have a Mazda Miata I have been tracking for some time and running Global Time Attack in. I am now looking to run NASA TT but not sure where to go. I went through the classification form and think I'm adding points incorrectly. Below I have listed my modifications. If someone can tell me what class I fall in, that would be great. 1990 Mazda Miata ENGINE: 1.8 motor (?? HP) Header Intake Exhaust Cat removed TRANS/DIFF: Stock transmission 1.6 flywheel VLSD SUSPENSION/CHASSIS: Koni yellow (single adj) Ground Control sleeves/springs Racing Beat front bar Rear bar removed Frame rail braces All poly bushings including diff mounts Delrin motor mounts BRAKES: 1.8 brakes Race pads WHEEL/TIRE: TR Motorsport 15x9 225/45-15 Hankook RS-3 INTERIOR/WEIGHT: Cage w. NASCAR bars Race seat/ stock passenger MOMO wheel NO A/C or P/S AERO: ABS air dam Front splitter Side diffuser (non functional) APR GT200 with riser (can remove) Half rear bumper Thanks everyone! Quote
TurboShortBus Posted September 19, 2013 Posted September 19, 2013 My suggestion is that you go through the classification forms, and look at each modification item. Ask yourself: Does my car have this modification? If "yes," then add the points. If "no," then move to the next one. Note that there is no "maybe" or "well, sorta." Despite what some people will say, we have tried to keep these forms as simple as possible, and they are pretty straightforward. Note that a fairly detailed mechanical knowledge of your car is required, especially if you bought it already modified. Alternatively, contact your regional TT director and/or somebody in your region who runs a Miata in TT. If I am your regional TT director, then please see my suggestion above. Remember: cut = modify remove = modify BTM = base trim model Mark Quote
circuitmstr Posted September 19, 2013 Posted September 19, 2013 If you want to class is at a 90 you will have to dyno reclass because that engine was not born in that chassis. However since you have 1.8 brakes you can points class it as a 94 . You will want to remove the frame rail bracing and side diffusers. neither are worth the points. Your best bet is probably to dyno reclass it as a 94 other wise take points for the 1.8 brakes (+2). remove splitter, side diffusers, rear wing (not necessary at near stock power levels) Whatever base class you get you will need to add +10 for suspension and +1 if you decide to keep your cut rear bumper. The rs3's are a 3 point tire and frankly prob wont be competitive in any scenario. Get some sm6's and figure out a way to stay in TTE Quote
matthewAPM Posted September 19, 2013 Author Posted September 19, 2013 If you want to class is at a 90 you will have to dyno reclass because that engine was not born in that chassis. However since you have 1.8 brakes you can points class it as a 94 . You will want to remove the frame rail bracing and side diffusers. neither are worth the points.Your best bet is probably to dyno reclass it as a 94 other wise take points for the 1.8 brakes (+2). remove splitter, side diffusers, rear wing (not necessary at near stock power levels) Whatever base class you get you will need to add +10 for suspension and +1 if you decide to keep your cut rear bumper. The rs3's are a 3 point tire and frankly prob wont be competitive in any scenario. Get some sm6's and figure out a way to stay in TTE Thank you for the info and help!I guess my question is with the rs3's with current setup, am I still TTE legal or TTD? Quote
kbrew8991 Posted September 19, 2013 Posted September 19, 2013 (edited) if you're not going to add up all your points, just put TTU on the car and run there Otherwise start with the '94 Miata base class and get to adding. Eyeball test / math of the top of my head comes up with a few points into TTD but that's unofficial and all that. Is there / are there mods you're confused on? Edited September 19, 2013 by Guest Quote
ILIKETODRIVE Posted September 19, 2013 Posted September 19, 2013 (edited) If you have a swap you HAVE to dyno reclass per TT rules. Therefore, without knowing whp and weight, we don't know what your new assigned base class is. (I don't know if Greg allows a 1.6 Miata chassis with a 1.8 Miata engine to be considered like it was originally a 1.8 Miata if you do the other mods that would bring it up-to-date/on-par with a 1.8 Miata) (I only see this: Mazda Miata (’90-’97): Replacement of the OEM/BTM '90-'93, '95 (with VIN's higher than 14193), '96-'97, and '99-'00 Mazda Miata ECU 4.0MHz "clock" crystal, and the OEM/BTM '94 and '95 (with VIN's lower than 14193) Mazda Miata ECU 8.0MHz "clock" crystal with an aftermarket crystal of different frequency, sometimes referred to as "overclocking" of the ECU, is permitted as a no-points modification.) Edited September 19, 2013 by Guest Quote
kbrew8991 Posted September 19, 2013 Posted September 19, 2013 are you SURE it's not 1994 Miata guts put into a shell that happens to have a 1990 VIN plate so long as you're taking points for any parts differences... Quote
matthewAPM Posted September 19, 2013 Author Posted September 19, 2013 My issue isn't adding. I have just seen Miata's with similar setups in TTE minus the wing. I am slightly confused about the tire rules. How many pts. for the kooks? The rest I understand better now. Sorry for all the questions. Quote
National Staff Greg G. Posted September 19, 2013 National Staff Posted September 19, 2013 '90 Miata with a 1.8L requires Dyno re-classing, period. We have gone away from classing '90's as '94's, etc. for most car models, as it gets very confusing. There are still re-classes out there like this, but they are, in general, being cycled through when the new re-class is required. Quote
kbrew8991 Posted September 19, 2013 Posted September 19, 2013 Tires are done two ways - width points and compound points Compound is always going to be the same no matter your base class. RS3s are specifically called out under A6 as an example of the 120-200 treadwear category at +2 pts Width points are going to vary depending on the BASE (not competition, base!) class of your car. A TTF base classed car takes points for the difference between their widest tire and 215mm width. A TTE base classed car takes points for the difference between their widest tire and 235mm width. So the same 225 width tire can be on a TTF base class car and cost +1pt for width, and be on a TTE base class car and give that car back 1 pt to spend elsewhere (or drop down a class if possible / depending). Hope that helps! That is one of the more common mistakes I see on class forms so don't feel bad about asking for clarification on it. Quote
ILIKETODRIVE Posted September 19, 2013 Posted September 19, 2013 (edited) My issue isn't adding. I have just seen Miata's with similar setups in TTE minus the wing. I am slightly confused about the tire rules. How many pts. for the kooks? The rest I understand better now. Sorry for all the questions. Tire points is easy once you understand it. If your car is assigned a TTE/TTE*/TTE** base class, your base tire size is 235. Therefore, you would get 1 point back (-1) because of the actual tire size (225) but you would take 2 points (+2) because of the tire compound. THEREFORE, they cost you 1 total point (+1). If your car is assigned a TTD/TTD*/TTD** base class, your base tire size is 245. Therefore, you would get 4 points back (-4) because of the actual tire size (225) but you would take 2 points (+2) because of the tire compound. THEREFORE, you get back 2 total points (-2). Edited September 19, 2013 by Guest Quote
circuitmstr Posted September 19, 2013 Posted September 19, 2013 If you ran it how it sits right now. Based on what you are telling us, you would want to class it as a 94. So your base class would be TTE. And you would have 33 points. So you would be in TTD with 6 points to spare. Unfortunately this setup would not be competitive. If you are taking points for something you need to make them count. IE: if you are taking diff points, you better have an OSgiken or equivelant. +1 intake +2 header +2 exhaust +1 no cat +3 lsd +7 suspension +3 frame rails +3airdam +3splitter +4 wing +1 bumper cut +2 skirts +1 225rs3s in TTE =33 Quote
National Staff Greg G. Posted September 19, 2013 National Staff Posted September 19, 2013 If you ran it how it sits right now. Based on what you are telling us, you would want to class it as a 94. So your base class would be TTE. And you would have 33 points. So you would be in TTD with 6 points to spare. Unfortunately this setup would not be competitive. If you are taking points for something you need to make them count. IE: if you are taking diff points, you better have an OSgiken or equivelant. +1 intake +2 header +2 exhaust +1 no cat +3 lsd +7 suspension +3 frame rails +3airdam +3splitter +4 wing +1 bumper cut +2 skirts +1 225rs3s in TTE =33 WRONG, it cannot be "classed" as a '94. As I posted, it requires a Dyno reclass, period. Thanks. Lets stop giving out misinformation here folks. Quote
circuitmstr Posted September 19, 2013 Posted September 19, 2013 Oops. my bad. I thought this was acceptable because I know of several others who have updated or backdated their miatas to be classed as different year or model. One of them won a national championship... Quote
