Al Watson Posted September 30, 2013 Posted September 30, 2013 (edited) Per the new RCR procedure, below is a list of the RCRs received for the 2014 rulebook and open for public comment. Please note RCRs for the 2014 rulebook are no longer being accepted. We still welcome any RCRs but they will be part of next years RCR process. Note: Y - being recommend for change N- not being recommended for change ? - still being kicked around RCR-SI-030813 N 5.7 remove scattershield language as spec trans/bell RCR-SI-030913 N 7.4.14 change 'must' to 'may' remove door windows (or remove all) RCR-SI-031013 N 7.4.15 change hood pins from 4 to 2 required RCR-SI-031113 N 7.4.17 remove FRPP tow hooks, require any brand RCR-SI-052513 N 7.1 clarify primary fuels such as pump gas and E85 permitted RCR-SI-061013 Y 7.4.3 add no california special bodywork in SI RCR-SI-072913 Y 7.14.13 any front swaybar endlinks permitted RCR-SI-073013 Y 7.14.9 HVT Shock package may be used RCR-SI-073113 Y 7.14.14 Ford racing M-18197-A upper rear shock mount may be used RCR-SI-091913 ? 6.1 power- change wght to tq ratio from 11.75:1 to 11.25:1 RCR-SI-092513 ? 7.5.2 request to remove weight % requirement RCR-SI-092613 ? 7.10.4 request to run only one ecu calibration RCR-AI-052613 N add to dyno spec sheet, fuel type used. RCR-AI-052313 Y 7.1 clarify primary fuels such as pump gas and E85 permitted RCR-AI-060613 Y add to dyno spec sheet, ABS type used, in calculations RCR-AI-062613 Y remove 7.3.g firewall mods for 2005 valvecovers RCR-AI-062713 N add 7.10.5 no active restrictors RCR-AI-092713 Y 7.4.3 add composite doors to the list RCR-AI-093013 Y 7.3.2 82-92 3rd gen F body allow to mod front side of strut tower RCR-AIX-052413 Y 7.1 clarify primary fuels such as pump gas and E85 permitted RCR-AIX-100113 Y 7.8.2 up rotor size from 14" to 15" Thanks, AL. Edited October 3, 2013 by Guest Quote
Track Junkie Posted October 3, 2013 Posted October 3, 2013 Per the new RCR procedure, below is a list of the RCRs received for the 2014 rulebook and open for public comment. Please note RCRs for the 2014 rulebook are no longer being accepted. We still welcome any RCRs but they will be part of next years RCR process. Note: Y - being recommend for change N- not being recommended for change ? - still being kicked around RCR-SI-030813 N 5.7 remove scattershield language as spec trans/bell RCR-SI-030913 N 7.4.14 change 'must' to 'may' remove door windows (or remove all) RCR-SI-031013 N 7.4.15 change hood pins from 4 to 2 required RCR-SI-031113 N 7.4.17 remove FRPP tow hooks, require any brand RCR-SI-052513 N 7.1 clarify primary fuels such as pump gas and E85 permitted RCR-SI-061013 Y 7.4.3 add no california special bodywork in SI RCR-SI-072913 Y 7.14.13 any front swaybar endlinks permitted RCR-SI-073013 Y 7.14.9 HVT Shock package may be used RCR-SI-073113 Y 7.14.14 Ford racing M-18197-A upper rear shock mount may be used RCR-SI-091913 ? 6.1 power- change wght to tq ratio from 11.75:1 to 11.25:1 RCR-SI-092513 ? 7.5.2 request to remove weight % requirement RCR-SI-092613 ? 7.10.4 request to run only one ecu calibration RCR-AI-052613 N add to dyno spec sheet, fuel type used. RCR-AI-052313 Y 7.1 clarify primary fuels such as pump gas and E85 permitted RCR-AI-060613 Y add to dyno spec sheet, ABS type used, in calculations RCR-AI-062613 Y remove 7.3.g firewall mods for 2005 valvecovers RCR-AI-062713 N add 7.10.5 no active restrictors RCR-AI-092713 Y 7.4.3 add composite doors to the list RCR-AIX-052413 Y 7.1 clarify primary fuels such as pump gas and E85 permitted Thanks, AL. So re 7.14.9, on the HVT shock package. The HVT package "may" be used, not "must" be used? Quote
Al Watson Posted October 3, 2013 Author Posted October 3, 2013 That is correct. These are the recommended changes the regional directors put together, The national director may accept, deny or change these. AL. Quote
stevepoe Posted October 3, 2013 Posted October 3, 2013 I guess my increase min weight ccr for si was not heard ? and the do away with the 53% weight percentage ? Quote
Al Watson Posted October 3, 2013 Author Posted October 3, 2013 RCR-SI-091913 ? 6.1 power- change wght to tq ratio from 11.75:1 to 11.25:1 RCR-SI-092513 ? 7.5.2 request to remove weight % requirement We got them Steve. Quote
Track Junkie Posted October 3, 2013 Posted October 3, 2013 It'll be interesting to see what happens. I have been running an economy shock package ( per the initial rule set) since March, and for me, it works great. Not sure why an expensive setup was mandated for a "budget" class. I do have a set of the HVTs uninstalled sitting in a box, waiting for final clarification. Thanks, Richard Quote
suck fumes Posted October 4, 2013 Posted October 4, 2013 So if the HVT package isn't mandatory then people can run whatever they want??? I wouldn't have dropped $2400 on it if I had known it wasn't going to be mandatory. Really takes the spec factor out and the competition won't be as close if its not mandatory. Quote
Al Watson Posted October 4, 2013 Author Posted October 4, 2013 I apologize on not being clear on the shock rule suggestion. The original rule was any $1000 shock and then HVT came on board as the spec shock per the tech bulletin. So we are suggesting the following change: remove the 'any $1000 shock rule' and add' hvt shock may be used'. Yes 'may' and not 'must'. So this allows either the oe shocks it came with or the HVT package and no others. Our reason for this suggestion is we feel it will help new SI cars get into the field at a lower initial cost, growing the class. Alot of other rules are 'may' or 'permitted' as well leaving the oe stuff open for use. The HVT package is far superior than a oe shock so its the ticket for performance, and oe shock is the ticket for budget folks. So 'any' shock is not the case. Quote
suck fumes Posted October 4, 2013 Posted October 4, 2013 Oooo ok good. Now it sounds better haha Quote
edhunter Posted October 6, 2013 Posted October 6, 2013 Per the new RCR procedure, below is a list of the RCRs received for the 2014 rulebook and open for public comment. Please note RCRs for the 2014 rulebook are no longer being accepted. We still welcome any RCRs but they will be part of next years RCR process. Note: Y - being recommend for change N- not being recommended for change ? - still being kicked around RCR-SI-030813 N 5.7 remove scattershield language as spec trans/bell RCR-SI-030913 N 7.4.14 change 'must' to 'may' remove door windows (or remove all) RCR-SI-031013 N 7.4.15 change hood pins from 4 to 2 required RCR-SI-031113 N 7.4.17 remove FRPP tow hooks, require any brand RCR-SI-052513 N 7.1 clarify primary fuels such as pump gas and E85 permitted RCR-SI-061013 Y 7.4.3 add no california special bodywork in SI RCR-SI-072913 Y 7.14.13 any front swaybar endlinks permitted RCR-SI-073013 Y 7.14.9 HVT Shock package may be used RCR-SI-073113 Y 7.14.14 Ford racing M-18197-A upper rear shock mount may be used RCR-SI-091913 ? 6.1 power- change wght to tq ratio from 11.75:1 to 11.25:1 RCR-SI-092513 ? 7.5.2 request to remove weight % requirement RCR-SI-092613 ? 7.10.4 request to run only one ecu calibration RCR-AI-052613 N add to dyno spec sheet, fuel type used. RCR-AI-052313 Y 7.1 clarify primary fuels such as pump gas and E85 permitted RCR-AI-060613 Y add to dyno spec sheet, ABS type used, in calculations RCR-AI-062613 Y remove 7.3.g firewall mods for 2005 valvecovers RCR-AI-062713 N add 7.10.5 no active restrictors RCR-AI-092713 Y 7.4.3 add composite doors to the list RCR-AI-093013 Y 7.3.2 82-92 3rd gen F body allow to mod front side of strut tower RCR-AIX-052413 Y 7.1 clarify primary fuels such as pump gas and E85 permitted RCR-AIX-100113 Y 7.8.2 up rotor size from 14" to 15" Thanks, AL. RCR-AI-062613 Y remove 7.3.g firewall mods for 2005 valvecovers.... Wondering what the purpose of this rule is... I run a pushrod engine in my 05 chassis, and with my tall valve covers and breather hoses the wiper bucket (not the cowl as defined by the rules in my estimation) on the passenger side is quite close to the valve cover. Getting the rear bolt off the valve cover is a real b*tch, so i used a rubber mallet and bent the bucket in a bit on the very bottom. It's not cut, and is still intact. It certainly is not a performance enhancer. The rules state the “ Cowl is described as the metal structure between the firewall and the base of the windshield" The wiper bucket does not go to the base of the windshield, so by definition is not part of the cowl. At least that's how I interpret it... Does this rule consideration mean my build will not be legal next year? Quote
stevepoe Posted October 6, 2013 Posted October 6, 2013 Richard you obviously have not been on the hvt package . no way a economy set compares to this system. it's a kick ass system and a steal for what is goes for . I even think some ai cars could work with the system with no problem .Our spec iron car is incredible to drive . Quote
suck fumes Posted October 6, 2013 Posted October 6, 2013 Per the new RCR procedure, below is a list of the RCRs received for the 2014 rulebook and open for public comment. Please note RCRs for the 2014 rulebook are no longer being accepted. We still welcome any RCRs but they will be part of next years RCR process. Note: Y - being recommend for change N- not being recommended for change ? - still being kicked around RCR-SI-030813 N 5.7 remove scattershield language as spec trans/bell RCR-SI-030913 N 7.4.14 change 'must' to 'may' remove door windows (or remove all) RCR-SI-031013 N 7.4.15 change hood pins from 4 to 2 required RCR-SI-031113 N 7.4.17 remove FRPP tow hooks, require any brand RCR-SI-052513 N 7.1 clarify primary fuels such as pump gas and E85 permitted RCR-SI-061013 Y 7.4.3 add no california special bodywork in SI RCR-SI-072913 Y 7.14.13 any front swaybar endlinks permitted RCR-SI-073013 Y 7.14.9 HVT Shock package may be used RCR-SI-073113 Y 7.14.14 Ford racing M-18197-A upper rear shock mount may be used RCR-SI-091913 ? 6.1 power- change wght to tq ratio from 11.75:1 to 11.25:1 RCR-SI-092513 ? 7.5.2 request to remove weight % requirement RCR-SI-092613 ? 7.10.4 request to run only one ecu calibration RCR-AI-052613 N add to dyno spec sheet, fuel type used. RCR-AI-052313 Y 7.1 clarify primary fuels such as pump gas and E85 permitted RCR-AI-060613 Y add to dyno spec sheet, ABS type used, in calculations RCR-AI-062613 Y remove 7.3.g firewall mods for 2005 valvecovers RCR-AI-062713 N add 7.10.5 no active restrictors RCR-AI-092713 Y 7.4.3 add composite doors to the list RCR-AI-093013 Y 7.3.2 82-92 3rd gen F body allow to mod front side of strut tower RCR-AIX-052413 Y 7.1 clarify primary fuels such as pump gas and E85 permitted RCR-AIX-100113 Y 7.8.2 up rotor size from 14" to 15" Thanks, AL. RCR-AI-062613 Y remove 7.3.g firewall mods for 2005 valvecovers.... Wondering what the purpose of this rule is... I run a pushrod engine in my 05 chassis, and with my tall valve covers and breather hoses the wiper bucket (not the cowl as defined by the rules in my estimation) on the passenger side is quite close to the valve cover. Getting the rear bolt off the valve cover is a real b*tch, so i used a rubber mallet and bent the bucket in a bit on the very bottom. It's not cut, and is still intact. It certainly is not a performance enhancer. The rules state the “ Cowl is described as the metal structure between the firewall and the base of the windshield" The wiper bucket does not go to the base of the windshield, so by definition is not part of the cowl. At least that's how I interpret it... Does this rule consideration mean my build will not be legal next year? It wouldn't surprise me as people were trying to get me thrown out at nationals for not having a cover over my freakin glovebox! Quote
Track Junkie Posted October 6, 2013 Posted October 6, 2013 Richard you obviously have not been on the hvt package . no way a economy set compares to this system. it's a kick ass system and a steal for what is goes for . I even think some ai cars could work with the system with no problem .Our spec iron car is incredible to drive . Thanks Steve, got the HVTs going in on Wednesday. We had two SI cars at Sebring yesterday. Both built by Iconic. One with, and mine without. I was consistently a second to a second and a half behind. I would love to blame it on the shocks and not my inconsistent attempt at driving. Quote
stevepoe Posted October 6, 2013 Posted October 6, 2013 you will like . it's a pretty solid system for the money . I was really surprised by it . We have been out 4 races on it now and we are really starting to get it dialed in. short tracks we can really keep up with ai cars we just get killed by hp and having no good 5th Quote
FR500S70 Posted October 9, 2013 Posted October 9, 2013 RCR-SI-091913 ? 6.1 power- change wght to tq ratio from 11.75:1 to 11.25:1 I support this change. The engines are biassed toward having higher torque numbers. This change is consistent with the spec iron theme while making the cars safer and easier to handle. Quote
FR500S70 Posted October 9, 2013 Posted October 9, 2013 RCR-SI-092513 ? 7.5.2 request to remove weight % requirement I also support this change. I would rather drive a car that the rear end does not want to swap ends with the front. This is a safety issue and has little to no financial impact on the cost of the car. Quote
Al Watson Posted October 14, 2013 Author Posted October 14, 2013 10/14/13 Update - rules suggestions submitted to aix/ai/si national director. Quote
smitty328 Posted October 14, 2013 Posted October 14, 2013 It wouldn't surprise me as people were trying to get me thrown out at nationals for not having a cover over my freakin glovebox! Cheater! Quote
