StDigital Posted November 9, 2013 Posted November 9, 2013 For Sale: One set of Toyo Proxes RR racing tires. These tires are for racing use only and are designed for dry track conditions. They are brand new and have never been used. They are leftover from last season. We don't use this size and they were ordered accidentally so our mistake is your gain. Brand new, zero heat cycles, good to go. Specs: Tire Size Product Code Approved Rim Width Range (inch) Measured Rim Tread Depth (1/32") Overall Diameter (inch) Overall Width (inch) Static Loaded Radius (inch) Revs Per Mile Price 225/50R15 255080 6.0-8.0 7.0 4/32 23.9 9.2 11.0 869 $180 - Racing tread compound designed for increased grip and improved lap times - Reinforced sidewall and High-Modulus bead filler provide excellent steering response and feedback - Wear inspection holes strategically placed around the tire provide easy tread depth measurement - Sidewall marking area designed with the racer in mind allows for easy labeling on the sidewall Operating Temperature: 160°F to 220°F Hot Inflation Pressures: High 30s to Low 40s (psi) Camber: -2.5° to -5.0° Caster: As much positive as possible If you're unfamiliar with these tires check out: philstireservice dot com for more details. They're up on eBay: http://www.ebay.com/itm/251374655016 I'm asking $400 Quote
StDigital Posted November 10, 2013 Author Posted November 10, 2013 $400 shipped to Phoenix Az.? Someone already bid on them in the ebay auction for $400 plus shipping. The auction doesn't end for a few days. Quote
