R13 Posted November 14, 2013 Posted November 14, 2013 So, looking towards the off-season. I've more or less established where I fall in the TTB field this year, and I've got some work to do. The good news: From where the car sits now, I have 10 points to play with (before any dyno reclass, assuming that would net me anything) The Question: What do I do with them? A minimum of 5 of those points will go towards stickier tires (NT01 or R888 so I can still drive to/from events on them since I don't trailer.....yes, I know....no, I'm not going to buy a tow vehicle, trailer, and A6s ). So, with the remaining 5 points, I could (within the scope of things I'm willing to do to the car/have a budget for): Increase the WIDTH of the better tires by 20mm (275 vs 255 in the rear with a 235 up front), and take ~20lbs out of the carOR Leave the tire width as-is (255R 215F) and drop ~60lbs out of the car I know tires are king, but I also know that the rotating mass and gearing change from a 275 rear isn't necessarily a benefit in the scheme of things vs. a 255 for my sometimes-torque-challenged car. Chucking weight out will mean the skinnier tires (and brakes and engine) will have less mass to contend with all around. Opinions on where I'll get the most figurative mileage there? Quote
ILIKETODRIVE Posted November 14, 2013 Posted November 14, 2013 I would vote keep sizing the same for now and just up to a better compound and ditch some weight. Pretty simple and should net solid results. Quote
kbrew8991 Posted November 14, 2013 Posted November 14, 2013 with the reclass you're going to get locked into a weight, can't use points for weight reduction below that, so width I guess. Quote
R13 Posted November 14, 2013 Author Posted November 14, 2013 with the reclass you're going to get locked into a weight Right, assuming I decided to pursue the dyno reclass vs. just eating the points for the current power mods and taking points for additional weight reduction.....which is probably another question on it's own. I'm sitting at a PWR of 11.35 right now. base class for my car is TTC** I would vote keep sizing the same for now and just up to a better compound and ditch some weight. Pretty simple and should net solid results. I'd been leaning that way, but wanted to validate. The tires would be cheaper, and at least a portion of the weight would come off the very nose and tail of the car. I just didn't want to shoot myself in the foot if there was some common knowledge to the contrary. Quote
R13 Posted November 18, 2013 Author Posted November 18, 2013 Better tires.. Absolutely. A minimum of 5 of those points will go towards stickier tires (NT01 or R888 so I can still drive to/from events on them since I don't trailer.....yes, I know....no, I'm not going to buy a tow vehicle, trailer, and A6s ). Yeah, on top of that part. Question is between 20mm in extra width for the better tires OR 60lbs off the car. (skinny better tires, and lose weight, OR wider better tires, but no weight loss) Quote
Varkwso Posted November 18, 2013 Posted November 18, 2013 Better tires.. Absolutely. A minimum of 5 of those points will go towards stickier tires (NT01 or R888 so I can still drive to/from events on them since I don't trailer.....yes, I know....no, I'm not going to buy a tow vehicle, trailer, and A6s ). Yeah, on top of that part. Question is between 20mm in extra width for the better tires OR 60lbs off the car. (skinny better tires, and lose weight, OR wider better tires, but no weight loss) I am a wider tire guy...other opinions may vary. Quote
sperkins Posted November 19, 2013 Posted November 19, 2013 Probably won't matter without more car prep. Compound trumps width without going to extremes. Quote
clydesdale Posted November 19, 2013 Posted November 19, 2013 Who needs a trailer to run Hoosiers? Quote
R13 Posted November 19, 2013 Author Posted November 19, 2013 Add a hitch and tow a tire trailer. I'd looked at that, but there really is not a good way to add a hitch to these things. I'm not actually aware of a single instance where someone's done it, and there are at least several in the community who track/autocross them. Quote
