FrankEC Posted December 20, 2013 Share Posted December 20, 2013 Just need some quick clarification from you guys- Rule E9: Replace or modify control arms (other than plates, shims, slots, or eccentric bolts/bushings for simple camber/caster adjustment only) or RWD/AWD rear trailing arms (may have spherical/metallic joint for the connection to the spindle/knuckle) +4 I have rear camber arms, they just allow me to adjust camber of the rear tires, but they do replace the factory lower control arms (same mounting points though). Are these gonna cost me 4 points? Thanks guys Frank Quote Link to comment Share on other sites More sharing options...
ILIKETODRIVE Posted December 20, 2013 Share Posted December 20, 2013 You drive FWD? E.10) Non-BTM rear control arms on FWD vehicles (for stiffness and wheel alignment only, no change in suspension mount or pick-up points from stock) +1 (if both front and rear use E.9) Quote Link to comment Share on other sites More sharing options...
FrankEC Posted December 20, 2013 Author Share Posted December 20, 2013 Nope it's an e36 M3, but the first part of E9 does not mention drivetrain- just states replace or modify control arms Quote Link to comment Share on other sites More sharing options...
kbrew8991 Posted December 20, 2013 Share Posted December 20, 2013 That method of camber adjustment isn't free - take E9 points or take the part off and use another route. Quote Link to comment Share on other sites More sharing options...
ILIKETODRIVE Posted December 20, 2013 Share Posted December 20, 2013 Nope it's an e36 M3, but the first part of E9 does not mention drivetrain- just states replace or modify control arms Because E.9) is for every make/model/drivetrain/etc. E.10) is specifically for FWD and swapping rear arms to gain camber adjustment. Quote Link to comment Share on other sites More sharing options...
FrankEC Posted December 20, 2013 Author Share Posted December 20, 2013 Anyone want a nice used set of rear adjustable control arms? Quote Link to comment Share on other sites More sharing options...
covingtonja Posted December 20, 2013 Share Posted December 20, 2013 Anyone want a nice used set of rear adjustable control arms? FYI...You're not alone on this. I was amazed that front camber plates are free, while rear arms are +4. Seemed crazy, but off mine came too...Crazy high points for this mod. Jason Quote Link to comment Share on other sites More sharing options...
FrankEC Posted December 21, 2013 Author Share Posted December 21, 2013 Yeah man DEFINITELY not worth 4 points! I mean rear camber can be adjusted anyway with the eccentric on the trailing arm, the camber arms just made alignments easier haha! Quote Link to comment Share on other sites More sharing options...
