dp Racing Dan Posted June 5, 2014 Share Posted June 5, 2014 So I've decided I want to do a Coyote Swap into the Drift Patrol. I need the revs, and really want the reliability of the new motor. The only way I can do that is by parting out the current motor/supercharger setup. I'm selling it ALL. From the MSD, blower setup, heads, intake, headers, etc etc etc. This image has been resized. Click this bar to view the full image. Report this image I'll be posting up a detailed list with pictures over the next few days. Contact me for questions- please contact me directly @ dpracingdan@ gee mail dot com or you can even text me @ 650 eight three four three nyne nyne three This image has been resized. Click this bar to view the full image. Report this image HERES a list of the parts I'm selling and prices. All these parts have about 10-hours of run-time max on them- many of them only a couple hours. This car is used for competition only- zero street use. All parts are used but in good working order. Heads - fms-m6049z304da7?(with valves, springs, and hardware)( I had 220 valves cut down to 194s to work on regular SBF (5.0) (were from BOSS 347 crate motor) $1000 Rockers- M 6564 F351 $300 Headers- M-9430-ZM7993 (discontinued!) (shorty putting Z heads into fox w VHT ceramic paint) $250 Trick Flow Track Heat Upper and Lower Intake manifold- silver powder coat- $475 Complete Blower Setup - Paxton SL1200 w after-cooler, electric RV Water Pump, 4 gallon water cell, 04 Cobra Heat exchanger, Vortech Power cooler, Race Bracket Upgrade, Upgraded discharge Tube and Mondo BOV, Silicone couplers, T-clamps, 8-Rib Belt Setup, spare pulley, Spare 8-rib belts, couplers, tensioner pulley/brackets, (battery sized) after cooler tank, smaller electric water pump, 15' of 3/4" water plumbing etc. (this system would cost $6000 to emulate) $3000 Paxton Fuel Rails (blue annodized- never used) - $150 Alternator- 130 Amp 3G- $75 Smog Pump Delete- $50 AC Delete- $50 Mini Starter-$75 March Performance Front Mounted Power Steering Brackets- March Performance 30038 - $100 March Performance 1979-93 5.0L Ford Pulley Kits 2210 – Retail $100 - $75 60 lbs Fuel Injectors (2 hours old) – $400 MAF - $175 K&N Filter- $50 60lbs injectors and matching MAF (2 hours old) - $600 Adjustable Fuel Pressure Regulator – $75 A9P ECU -(2 hours old) $100 Throttle body and spacer - $175 Aluminum Water Pump- $50 (I have 2) EGR- $25 IAC- $30 Wires- $50 (about 4 sets- FMS, Taylor, MSD, etc) MSD Distributor- $225 Cap & Rotor – $30 MSD Coil- $30 MSD 6AL Box –$175 Trick Flow Valve Covers- Powder Coated Silver- (modified- 3/4" breathers added to each) -$75 Quote Link to comment Share on other sites More sharing options...
