Members Xavier C. Posted June 10, 2014 Members Share Posted June 10, 2014 (edited) In picture: CRX center tail light assemblies - ok condition 1 is cracked - $10/each Oil cooler setup includes Setrab cooler, lines, remote oil filter assembly and in/out spin adapter - $125- this includes the new NAPA gold (wix) filters I have (3). OBD1 dist - $35 CRX Mirrors - $5 / each Mishimoto Radiator Hoses upper is slightly cut to shorten it some. - $15 Starter - $10 / ea Crank pulley - $5 / ea Autometer "analog" oil pressure gauge - $15 OBD0 dist w/ wires - $50 New OBD0 and 1 dist caps/rotors - $10 /ea OBD1 IM has most sensors and all injectors - $15 New EF rear hub - $20 180 Stant Thermostat - $1 Mishimoto Thermostat - $10 OBD0 o2 sensor - $5 Honda Cam gear seals - $5 Main relays, used but works - $5 MSD Blaster Coil - $10 Hawk - Si rear pads - DTC-30 - $40 Hawk - Integra DA - DTC-60 - $65 DA Front calipers - $20each Blue valve cover - $10 DA lower Ball joints new - $15/each Honda fuel filter - $20 Tail light assemblies - $20 each Centric Rear Brake disc - $20/pair Hardrace front upper control arm bushings - $40 Blox rear v2 compensator arm to give higher toe adjustment - $40 1 qt - Honda MTF - $5 Clutch Cable - $15 Speedo cable - $10 Upper timing belt cover - $5 Used Oil Pump - $5 Radius Rod - $5 Small Battery box - $1 Gorilla security lug lock nuts (with key obviously) - $10 2 OBD0 Throttle bodies w/ functional TPS - $10 / ea set of CRX doors - complete - $40 /each front bumper with beam - $50 CRX Hatch - $35 Rear bumper w/ beam - $35 Fenders - $20 Front lower control arms - $15/ea Rear lca - $15/ea Radius rods - $10/ea Cable 40mm transmissions - $75/each 1 Transmission with a fresh set of gears and a 4.9FD but no diff (was supposed to be my spare) - $450 (pretty much cost of FD but free case!) D16a head OEM unmolested - $50 D16y7 head - OEM - $50 D16a shortblock, complete with ACL bearings with high compression pistons - $350 Edited October 15, 2014 by Guest Quote Link to comment Share on other sites More sharing options...
Ev Posted June 10, 2014 Share Posted June 10, 2014 How much for the dog? JK Good luck with the clean out... Quote Link to comment Share on other sites More sharing options...
audiobuffru12 Posted June 11, 2014 Share Posted June 11, 2014 wish you were closer, could use some extra parts for my Si. Quote Link to comment Share on other sites More sharing options...
Members Xavier C. Posted June 14, 2014 Author Members Share Posted June 14, 2014 if you're interested, in a decent amount I'll still be at track events and can bring some if you want to get some that way. btw - I've added a lot of parts. Quote Link to comment Share on other sites More sharing options...
Members Xavier C. Posted September 18, 2014 Author Members Share Posted September 18, 2014 Updated this post - I'll be at VIR on the first week in October and can bring any of this stuff to save on shipping. Quote Link to comment Share on other sites More sharing options...
Members Xavier C. Posted October 15, 2014 Author Members Share Posted October 15, 2014 Updated pictures and prices Quote Link to comment Share on other sites More sharing options...
PDM075 Posted November 28, 2014 Share Posted November 28, 2014 Interested in tranny with gear set. Can email direct... donpdm at gmail dot com Quote Link to comment Share on other sites More sharing options...
