Yellow Snake Posted October 26, 2014 Share Posted October 26, 2014 FOR SALE OR TRADE 98’ MUSTANG COBRA RACECAR. COMPLETE OR WILL SEPARATE. 25,538 original miles on car. 301.20 RWHP 294.58 RWTQ. Over $58,000.00 invested. ENGINE AND DRIVETRAIN 4.6 L Teskid Block Canton oiling system pan, cooler, thermostat, remote oil filter w/Fragola S.S. lines & fittings (Redline Oil) Accusump 3 quart w/electric solenoid Modified BBK 62mm throttle body w/matched intake Walbro 255 LPH fuel pump BBK adjustable fuel pressure regulator WMS C.A.I. Pro-M 87 mm MAF BBK LT ceramic coated headers w/stage 8 bolts BBK off road H pipe ceramic coated Flowmaster ceramic coated mufflers MSD DIS-4 w/MSD coils and Thunder Volt 10mm wires Braille light weight battery Taylor 4 pole master disconnect switch Auto-Rod Controls master switch panel 8 positions Custom crankcase breather system LFP/Fluiddyne 4 core aluminum radiator Meziere electric water pump SCT X3 Tuner Steeda billet clutch quadrant and firewall adjuster Innovators West underdrive crankshaft dampener Ford racing aluminum driveshaft HPM driveshaft safety hoop Torsen T-2R limited slip diff. 31 spline Moser 31 spline axles w/ARP studs Moser aluminum rearend cover Ford racing 3.73 and 4.30 gear sets Pro- 5.0 shifter Ford Racing A/C delete SUSPENSION AND CHASSIS Complete 1 ¾” D.O.M. roll cage with foot well protection Custom 1 ¾” D.O.M. front & rear bumpers Custom upper steering shaft w/removable Momo steering wheel Flaming River lower solid steering shaft ASP solid motor mounts ADDCO front sway bar w/Steeda aluminum mounts Kenny Brown matrix subframe connectors Complete Maximum Motorsports track package Koni double adjustable coilovers BRAKES Front Brembo 4 piston w/Hawk DTC 70 pads Rear stock w/Hawk DTC 60 pads Baer 2 piece rotors front & rear Spare Brembo front & stock rear rotors Russell S.S. brake lines front & rear Quantum Motorsports brake cooling ducts WHEELS AND TIRES 4 18X9.5 2000 Cobra R wheels and 4 18X9 & 18X10 Ford GT wheels w/295 & 305 Toyo R888’ EXTERIOR AND INTERIOR Complete set of Pro Glass molded Lexan windows still has protective coating Cervinis 2000 Cobra R front bumper cover Ford Racing 95’ Cobra R hood w/billet hood pins Cobra Sebring Pro Kevlar w/side alloy mounts FIA certified Simpson 6 point FIA harnesses G-Force window net Longacre 14” convex mirror SRP racing pedals Autometer Phantom gauges Contact Jerry 605-351-7110 or email [email protected] Quote Link to comment Share on other sites More sharing options...
