suck fumes Posted January 7, 2015 Share Posted January 7, 2015 Anyone know if the enkei RPF1 18x9.5 38mm offset wheels fit over the 14" gt500 brakes? Quote Link to comment Share on other sites More sharing options...
philstireservice Posted February 15, 2015 Share Posted February 15, 2015 Anyone know if the enkei RPF1 18x9.5 38mm offset wheels fit over the 14" gt500 brakes? Not likely - but these will Apex 18x9.5 ET35 Quote Link to comment Share on other sites More sharing options...
suck fumes Posted February 25, 2015 Author Share Posted February 25, 2015 Okay so I know they work cause Andy McDermott uses them on his A-sedan car. Now I just need to find out the offset? Quote Link to comment Share on other sites More sharing options...
Cheyne Posted February 25, 2015 Share Posted February 25, 2015 Andy doesn't use them in AS. He uses a 17x8 wheels since he runs full prep with 12" brake rotors. In the past year the full prep AS cars got an upgrade from 16x8 to 17x8 wheels, but their brakes stayed the same. Now I do use 18x9.5" Enkei RPF1's since I run AS Restricted Prep. The wheels I use are 45mm backspace, but I run a 3/4" spacer on the front. Cheyne Quote Link to comment Share on other sites More sharing options...
T&A Racing Posted February 26, 2015 Share Posted February 26, 2015 I have run pf01 with 45 mm offsets and they clear the Brembo big brakes 14 inch rotors no problems. Most places will ship you one wheel as a test fit, and let you return it. Quote Link to comment Share on other sites More sharing options...
