HAZE Posted March 16, 2015 Share Posted March 16, 2015 Hey guys. I've got a n00b question regarding TT classing. Say I have a car that's been dyno-reclassed as TTE (no points). Can I downclass back into TTF by running a narrower tire? Since a -30mm tire is -7 points, I'd still have 6 points to play with for mods and stay in TTF. Is this valid? I can't find anything specific in the TT Rulebook about this. Thanks! Quote Link to comment Share on other sites More sharing options...
TurboShortBus Posted March 16, 2015 Share Posted March 16, 2015 Say I have a car that's been dyno-reclassed as TTE (no points). Can I downclass back into TTF by running a narrower tire? Read your dyno reclass e-mail from Greg. Does it specifically state that the car must compete in TTE or higher? Dyno reclass e-mails typically state this, but I suppose that there could be some exceptions that I haven't seen yet. Mark Quote Link to comment Share on other sites More sharing options...
HAZE Posted March 16, 2015 Author Share Posted March 16, 2015 You're exactly right, I missed that part. "This option may only be used with a TTE or higher final class" So would this approach be valid using the base classing listed in the rulebook? Thanks for the help! Quote Link to comment Share on other sites More sharing options...
Members Mike W. Posted March 17, 2015 Members Share Posted March 17, 2015 (edited) You're exactly right, I missed that part. "This option may only be used with a TTE or higher final class" So would this approach be valid using the base classing listed in the rulebook? Thanks for the help! Yes, it would be valid to do that if your base classing in the rulebook is E, assuming you do not have too many mods already. You still have to be complaint with the power to weight for F then also. Edited March 17, 2015 by Guest Quote Link to comment Share on other sites More sharing options...
kbrew8991 Posted March 17, 2015 Share Posted March 17, 2015 rare to see but is allowed under the right circumstances Quote Link to comment Share on other sites More sharing options...
