Smike Posted June 19, 2015 Share Posted June 19, 2015 (edited) 1967 Sunbeam Alpine V $2,500 OBO Email: dgpartsales @ gmail Phone number: 248 six six zero 0 44 eight Location: Akron, OH Price: $2,500 without donor motor trans. Can talk about those too if interested. History: I purchased this car a few years ago as a rough driver - great for racecar conversion. Good bones and structure. This car can go a dozen different ways. Swap in a Ford small block - Tiger. Swap in I4 - cooler Miata. Curb weight is 2200 lb on a stock Alpine. Target weight in this trim is much lower. Car is titled and was driven on the street (has tags). Race NASA, SCCA, Lemons, Vintage. Engine: Stock 1.8L (82-93hp) has been pulled for swap - still have assembled if someone wants to swap back in Donor motor is a 2.3L from a Ford Ranger w/112 hp Donor motor has new - spark plugs and wires, coil packs, alternator, water pump, fuel filter, oil filter The 2.3L Ford used a 2nd spark for emissions - delayed spark chased combustion cycle to scavenge. I have re-wired for 2nd spark to fire on main cycle - better burning of combustion cycle...more power! Drivetrain/Transmission: Stock 4 speed is with motor and can be swapped back in. Shifted smoothly and no grinding Donor transmission also shift smoothly Chassis: Mark McMahan (Rollcageguy.com) 6pt custom NASA/SCCA legal roll cage with gussets and tied into frame Mark also made an aluminum rear deck that flows very nicely where the convertible top went New OE suspension shocks and struts Windshield and seats have been saved. This car did not have a top when I purchased Brakes: Front calipers rebuilt with new seals and stock pads Rear drums rebuilt with new shoes Wheel/Tire: 13in OE wheels in the car now 4x108 bolt pattern (Mustang IIs used same pattern) with new Goodyear SX4 tires Interior: All wiring and gauges still in car and unmodified Donor Ford 2.3L wiring harness, connections, and ECU pulled for easy install Body: Overall good. The headlight bezels were rusted when I purchased the car. I've removed all the rusted sections and covered openings with a solid metal plate for now. Can cut in whole for headlights or leave for racecar. All trim has been kept including headlight trim. French in or screw back on to complete Sunbeam look. Aluminum headlight covers from a Cobra replica car fit this as well. Door handles have been shaved. And front bumper has a GT350 look. Spares/Misc: OE Windshield OE Seats Trim and bumpers Photos: Edited November 11, 2016 by Guest Quote Link to comment Share on other sites More sharing options...
Smike Posted July 9, 2015 Author Share Posted July 9, 2015 New price! Looking to move this car! Quote Link to comment Share on other sites More sharing options...
Smike Posted August 9, 2016 Author Share Posted August 9, 2016 TTT Quote Link to comment Share on other sites More sharing options...
