tbruen01 Posted September 11, 2015 Share Posted September 11, 2015 So I was going through the Rule book (Club codes & Regulations) trying to determine if this car I am looking at this weekend actually had a legal cage or not. They state that the cage is legal for NASA but I wanted to make sure before I purchase something and find out it has to be replaced. I understand the basic design of the cage and how it should be set up, but can you have the cross bar behind the driver curve to create more room for a seat? 15.6.12 states that you need 2 bars for side impact. Can the two bars be parallel of each other or do they have to cross/connect at some point? Thanks, Tyler Quote Link to comment Share on other sites More sharing options...
tbruen01 Posted September 11, 2015 Author Share Posted September 11, 2015 This is the vehicle. Quote Link to comment Share on other sites More sharing options...
ILIKETODRIVE Posted September 12, 2015 Share Posted September 12, 2015 That looks like a modified weld-in Autopower or Kirk Racing cage. Some larger pictures and more close-up pictures would help. Also would need to know how thick the base plates are and size/thickness of the tubing. Also would need to confirm it is DOM and not ERW. Quote Link to comment Share on other sites More sharing options...
kbrew8991 Posted September 14, 2015 Share Posted September 14, 2015 Knowledge of if it has a logbook, when the logbook was obtained, and when it was last inspected to be raced would also help... I don't spy any red flags from those 3 pictures, but a more thorough in person inspection by an actual tech inspector may turn up something I'm not noticing. Quote Link to comment Share on other sites More sharing options...
davidfarmer Posted September 21, 2015 Share Posted September 21, 2015 NASA requires 2 bars, either independent or an X style. It doesn't specify anything else. Some classes have restrictions regarding extra connection points, but as long as the driver has 2 bars, you are fine z. Wedged plates must be 0.080", bolted 3/16" thick. GCR is pretty clear, and pretty reasonable Quote Link to comment Share on other sites More sharing options...
