johngeorge Posted October 28, 2015 Share Posted October 28, 2015 Toyo rr tire is classified in the same category as Hoosier A7 tires. We all know the Toyo rr performance is no where near Hoosiers A7, 2sec/lap slower from my experience. Proposal: add an additional +.xxx to anyone running Toyo rr following the same sizing formula now. Quote Link to comment Share on other sites More sharing options...
ILIKETODRIVE Posted October 28, 2015 Share Posted October 28, 2015 Toyo rr tire is classified in the same category as Hoosier A7 tires. We all know the Toyo rr performance is no where near Hoosiers A7, 2sec/lap slower from my experience. Proposal: add an additional +.xxx to anyone running Toyo rr following the same sizing formula now. I've always thought there should be a DOT tire split; A-compounds taking a slight hit to PTW or 100+ treadwear tires getting a slight bump. Quote Link to comment Share on other sites More sharing options...
Members Brian L. Posted October 30, 2015 Members Share Posted October 30, 2015 Different tires affect different cars differently. Making a blanket statement that tire A is 2 seconds faster than tire B cannot be accurate across the board. Therefor trying to come up with a .xxx penalty for similar tire types is nearly impossible and will only cause a LOT of complaints. There are some things in the ST class that need to be accepted, for example if a Hoosier A7 is faster than a Toyo RR, then run a Hoosier A7. That is just my opinion obviously. I personally ran R7's this last season, but I will be making the switch to A7's for 2016, because they are faster. Quote Link to comment Share on other sites More sharing options...
johngeorge Posted November 3, 2015 Author Share Posted November 3, 2015 I was only referring to toyo rr as a tire (no other brands) because Toyo is the official tire of NASA. Quote Link to comment Share on other sites More sharing options...
Members Brian L. Posted November 3, 2015 Members Share Posted November 3, 2015 I was only referring to toyo rr as a tire (no other brands) because Toyo is the official tire of NASA. That is true, but it is not the official tire of every NASA class. NASA does a great job in my opinion of having a great partner like Toyo involved in a lot of NASA series without playing favorites. From what I understand Toyo makes a full slick called the RS1 and it is supposed to be very quick. If you want to run a Toyo in a fast, non spec tire class like ST, then that is probably your best bet. Quote Link to comment Share on other sites More sharing options...
Greg Smith Posted November 9, 2015 Share Posted November 9, 2015 I'm against this proposal. Quote Link to comment Share on other sites More sharing options...
robbodleimages Posted November 12, 2015 Share Posted November 12, 2015 I've raced on the Toyo RS1 slick. As is typical with Toyo, the tire lasts long and is slow to the same degree. In this case a RS1 is as fast as a fast DOT, but not competitive against other slicks. I have a good older set that I use for shakedown laps. Quote Link to comment Share on other sites More sharing options...
National Staff Greg G. Posted November 12, 2015 National Staff Share Posted November 12, 2015 Guys, we are not adding any other Mod Factors for tires in ST1-ST3. These types of proposals may be appropriate for the potential lower ST classes in the future, though. Quote Link to comment Share on other sites More sharing options...
