docwyte Posted March 14, 2016 Share Posted March 14, 2016 I’ve owned this car for 6 years and swapped it shortly after I got it due to the factory motor having unreasonable amounts of blow by. I initially put in a used motor from a 2002 Camaro SS but after three years went to a built 383 stroker motor. This car is incredibly fast and will easily run down 996 GT3’s at the track while being docile driving around town. I built the car as a street/Time Trial car, as such it still has niceties such as air conditioning, cruise control, stereo etc. Everything on the car works, power windows, sunroof, the aforementioned A/C and so on. I went through the process of getting the car emissions inspected in the state of Colorado, its 49 state emissions compliant, not currently compliant for California although with some work it could be. The swap has received Colorado states blessing and the car gets tested as a ’02 Camaro SS. It easily passes emissions every time I’ve gone, it fast passed the last time I took it last spring. All body panels are original and still have the VIN tags on them. Most of the paint is still original and being 25 years old is showing its age. It looks good, but has lost some of its luster. The graphics are vinyl and will easily peel off. The nose/bumper show typical rock chips and there’s a small “outtie” dent above where the throttle body sits on the hood. The car is straight, no accidents, no stories. I’ve extensively gone through this car mechanically in the past six years and have basically rebuilt the entire car with all new parts. I’ve added/fabricated many parts that aren’t part of a normal LS swap to keep the car happy and running correctly long term such as a custom oil cooler, power steering cooler, auxiliary radiator and adding modern ABS from a Porsche Boxster. The motor was built by Thompson Racing and has less than 3000 miles on it. I’ve been competing with NASA Time Trial Group 2, which has a power to weight limit. That’s constrained the current motor power wise, a cam swap would probably add upwards to 50 more horsepower at the wheels; as it currently sits its making 422rwhp and 410 ft lbs at the wheels. All wear items on the car have less than 5000 miles on them. I have an extensive set of spares including body panels, wheels/tires and the like that can also be included with the sale but will be priced separately from the sale of just the car. I will not part out the car or my spare parts unless the car sells as is, whole first. Asking price for the car is $25,000 obo. Please look at my build threads on Rennlist and the 944 Hybrids forum: http://rennlist.com/forums/944-turbo-and-turbo-s-forum/585050-the-ls1-swap-has-begun.html http://944hybrids.forumotion.com/t862-it-begins Video here on YouTube: Here’s the build sheet on the car showing all the parts that it has. Engine Thompson Motorsports Built 383 Stroker Motor, installed Summer 2014 TMS 4340 stroker crank TMS 4340 Forged H beam rods with ARP rod bolts RHS 232cc CNC heads with .650” Dual valvesprings GM rockers with Comp Cams trunion upgrade TMS LS7 lifters Melling HP oil pump PSI engine wiring harness FAST 92 Intake Manifold FAST 92 Throttle body Custom siamesed cold air intake Engine Power Systems 226/230 cam Kooks 1 7/8” primary 3” collector long tube headers Custom dual 2.5” exhaust with magnaflow muffler and tips Custom dyno tuned by MAC Autosport Removable 3” smog legal cats Test pipes to replace cats Spec stage 2 clutch Spec aluminum lightened flywheel QuickTime bell housing with scatter shield Turn One power steering pump Evans Cooling Water pump SLP 180* thermostat KaTech Tensioner Ron Davis/Renegade Hybrids radiator 2004-2007 Audi S4 Auxiliary side mount radiator Mocal oil cooler Power steering cooler OBD2 port with Check Engine light Completely smog legal in 49 states, passed Smog Referee Certification in Colorado 914 drivers side headlight motor Texas Performance Concepts (TPC) New style uprights/set back plates and motor mounts Brake master cylinder plate ½” cross member spacers Oil pan and pick up tube Oil filter relocation kit Vehicle speed sensor kit Fuel filter kit Transmission Factory 1989 Turbo S “AOR” transmission Factory transmission cooler Factory limited slip differential Naturally Aspirated 5th gear Rebuilt shift linkage and shift rod Brakes Porsche Boxster ABS pump/ECU Ford Mustang hydroboost with Porsche 944 Turbo Master Cylinder Porsche 993 Turbo “Big Red” front brake calipers with 964 Turbo front brake rotors Porsche 944 Turbo S rear brake calipers and brake rotors Tilton infinitely adjustable rear brake proportioning valve Suspension Bilstein Escort Cup Coilovers Rebuilt/Revalved by Bilstein 450lb front 700lb rear springs Racers Edge Camber plates Racers Edge 2.25” front upper spring hats Front strut bar Rear torsion bar delete Elephant Racing Spherical bearings Elephant Racing rear trailing arm bearing blocks 968 M030 adjustable swaybars Car aligned and corner weighed by Chris Cervelli Interior Custom welded Hanksville Hotrods rollbar Schroth Profi 2 6 point harnesses Momo “Competition” steering wheel with quick release Airbags disabled, no airbag light on dash 3 gauge panel in center console with: Autometer water temp gauge Autometer oil temp gauge AEM wide band Air/Fuel gauge Sony MP3/iPod player Recaro SPG XL seats IO Port rollbar camera mount All factory gauges work A/C works, cruise control works, everything works Sony MP3 player with iPod and USB inputs Exterior Factory Guards Red paint Aerolatches hood pins (2) for hood 4 Carbon Fiber reverse louver hood vents Fiberglass front splitter, unknown brand 968 Door handles Curt tow hitch All original factory matching panels with VIN stickers Wheels/tires OEM Porsche “MY02” 18x8” front, 18x10” rear wheels Continental Conti sport tires Quote Link to comment Share on other sites More sharing options...
