Timeless Posted March 29, 2016 Share Posted March 29, 2016 I bought this less than a year ago and only put a few hundred miles on it. Here is the original for sale link: http://www.norotors.com/index.php?topic=22386.msg289886#msg289886 Here is current Craigslist ad: http://columbia.craigslist.org/cto/5496467991.html Since buying this, I've had done/added the following: 93 octane dyno tune (305whp) Nitto NT-05s (255 front/274 rear) New Quick Release Steering Wheel Magnaflow Mufflers (the straight through ones that came on the car were unbelievably loud No rotors premium floor mats (black mats with red no rotors lettering) Also purchased the following but have not installed: Hood latch cable 3 Gauge CF mold to replace dash idiot light cluster area Car drives great and has not given me any problems. A few items that the previous owner did not address and neither have I are as follows: Rear end bushing needs replacing (you can hear it squeak over bumps) LS1 Tick. The tick comes on after warming up slightly and goes away after full warm up. Some people don't care but I am a bit OCD and would have addressed this at the same time I was planning on adding a baffled oil pan/better rods/springs/possible better oil pump. I've been told it is probably a sticky lifter. Water Coolant gauge does not appear to work. Most likely easy fix. Gas gauge goes to about 3/4 full when fully filled so that would need to be fixed. Why am I selling? Few reasons. I've had some unexpected expenses come up (foundation repair on a rental property) and I don't see myself having the time to enjoy/learn the car. My plans were road racing (HPDE) events as the car is light especially since it is very basic (no power locks,doors,steering/no AC/no sunroof). So if you have not looked at the previous sale link here are the details: 1998 LS1 engine with 108k, 99 wiring harness and PCM 2001 T56 with 140k Ram Powergrip Clutch MGW Short Throw Shifter Custom 3.5" Cold Air Intake C6 Corvette exhaust manifolds 2.5" x-pipe C4 corvette drive shaft Ronin LS1 Mount kit C4 Corvette aluminum radiator Ford Focus Cooling fans Lokar Throttle cable Fragola PTFE Stainless steel braided lines and fittings, PTFE hose won't break down like normal fuel line and its ethanol resistant. Walbro 400 LPH Fuel Pump Corvette Fuel Filter Integra Speedo Mod Aftermarket Hood and front bumper (Ronin or Ronin clone) KYB AGX shocks Ground Control Coilovers Stainless steel brake lines Mazda 929 Brake Master Cyl 7/8 Wilwood Clutch Master Cly Stainless Steel clutch line. Quick release steering wheel Drag DR-31 wheels 17x8 fronts and 17x9 rears Optima Gel Cell Battery Aluminum Battery bracket 150 AMP battery Circuit Breaker Complete Turbo II brakes and rear end Bought the car September last year for $ 7500.00 (driven only on nice days since then so very few miles) Dyno Tune (performed at Panic Motor Sports here in Columbia SC) cost me $ 450.00 Nitto NT-05 tires installed (Nuttals tire here in Columbia SC) cost me $ 850.00 No Rotors floor mats cost me $ 150.00 Hood latch cable and 3 gauge CF dash mold cost me $ 125.00 New Quick Release Steering Wheel cost me $ 125.00 Magnaflow Mufflers (installed by The Muffler Shop here in Columbia SC) cost me $ 300.00 So grand total is $ 9,500.00 for everything. Asking $8000.00. Some pics (click on previous for sale ad for lots more!): http://s230.photobucket.com/user/TimelessSmurF/library/1986%20LS1%20Swapped%20RX7?sort=3&page=1 Please PM me with any questions. Thanks, Sean Quote Link to comment Share on other sites More sharing options...
Timeless Posted April 15, 2016 Author Share Posted April 15, 2016 SOLD! Quote Link to comment Share on other sites More sharing options...
