Traffic Posted April 27, 2016 Posted April 27, 2016 General: 2014 NASA AZ TTD 2nd Place (Rookie Season) 2015 NASA AZ TTD 1st Place 2015 Wild Horse Pass Lap Record NASA TTD Car is still 130lbs over class weight Has Cold AC, Heater, and wipers Comprehensive records and setup notes Get in and go fast today! Engine: Stock M52 174hp on recent dyno Good compression tests and oil analysis Welded oil pump nut Oil Pan Baffle AKG Engine and Transmission Mounts Spal electric fan Suspension: AST 4150s rebuilt last season Vorshlag Camber Plates Spherical Rear Shock Mounts UUC swaybar All bushings AKG Rear Trailing Arm Bushings with limiting Shims Front & Rear Subframe Reinforcements Rear Trailing Arm Pocket Reinforcements Wheel Bearings Drive Line: Refurbished transmission: New seals, shift detents, and springs, shift linkage bushings JB Racing Lightweight Flywheel and very recent clutch Blanton 3.73 LSD – 3 clutch – have build spec sheet Rebuilt half shafts with redline grease Brakes: Rebuilt Calipers Ducted rotors DTC-60s SS Lines Wheels and Tires: Hoosier R7s (One set 2 heat cycles) Hoosier R7s (One set 4 heat cycles) Kosei K1s 17” Wheels (2 Sets) Stock wheels for garage and trailer 10mm spacers High end wheels studs (don’t remember which brand) Full Spares package including: Transmission 4.10 diff parts Half shaft Pads Alternator Power steering pump Coil pack etc. $11,500 or make me an offer I can't refuse. Please email [email protected]. Quote
