points question
Hey all, hopefully these are easy ones.
Slotting your strut tower to get a little more caster.
Would you take points for this? Possible E13, relocation of front suspension mounting points.
Best +2 tire in 225/45/16 or 225/50/16 of the ones listed below and are they +2 tires?
Direzza ZII Star spec
Proxies R1R
Potenza RE-11
  • National Staff
Page 37 of the TT Rules
I. NO-POINTS MODIFICATIONS:
e. Suspension
1) Simple camber, caster, and toe adjustment by any method that does not alter suspension
mounting points (unless the modification used is otherwise assessed points above--such as
control arm, ball joint, and relocated mounting point modifications). Slotting of the BTM
bolt holes and removal of material from the top surface of the BTM strut/shock tower to the
extent necessary to allow simple camber/caster adjustment is permitted.). Bolt on
camber/caster plates are not assessed points.
  • 5 months later...
i would run the star spec. but I really like my hankook rs3 v2.
I have had identical sized RS3 v2 and Dunlop z2 star specs back to back and the RS3s were much faster. This was on a 2006 s2000 running staggered 245f/255r tires.
