944CS Posted July 1, 2016 Share Posted July 1, 2016 Fresh IP Build, dyno time only - 255whp on a conservative Mustang dyno, IP Dominator Cams, brand new genuine BMW lifters, Supertech springs/retainers, proprietary valve job/headwork done by ex-Penske R&D engine builder - best legal headwork there is - Race rod & main bearings, upgraded oil pump sprocket/shaft with left hand bolt & safety wire, ARP hardware - stock S52 Rods were magnafluxed and re-sized after ARP rod bolts were added, entire rotating assembly balanced to within 1gram Only selling because I don't have time to run with BMW Club in the foreseeable future $7900 in IP configuration or $6900 if you just want stock M3 cams for GTS2 Located in Long Island, NY Quote Link to comment Share on other sites More sharing options...
