FS: 1989 Honda CRX Si - Honda Challenge Prepped
Putting my racecar up for sale because I recently bought a house and the money is needed for updates. I am also getting married in August. I have had this car for close to a decade and I have a lot of time and money invested into it. No corners were cut on this build and no expense was spared. It was recently inspected and registered in West Virginia. Clean WV title in hand.
The car is prepped for H2 in Honda Challenge races, but you can run whatever you want with it. I have done mostly DE1 and DE2 class racing in it. I have ran SMF and XP class in Autox and the car was very competitive. Never had it at the drag strip, so I have no idea how fast it is in a quarter mile.
You can find videos of it on youtube. I will post one below for reference. You can find other's under the same account name. It is my friend who did a lot of R&D on the car.
No I do not have a transponder or any logbooks. I have maybe 20 hours seating time in this car. Everything is up to date for the most part including the seats, belts, etc. This is a turn key race car and I think the price is very reasonable being that I have way more than my asking price invested into it.
I am not really looking for any trades, mostly a cash deal. I would consider a four wheeler on top of cash.
$13,500 with everything listed below
$12,700 i keep the RPF1's
Below is the parts list, but I'm sure that I am forgetting a lot. Please text me if you have any questions and I also ask for no negative comments or bashing. I will not entertain it. Thanks!
Brad (484) 942 0786
Engine:
(John Kerr) JK Tuning Tune on 93oct - 190hp
JDM GSR (B18C) - motor had 30k miles on it when I purchased it over ten years ago
Innovative Motor Mounts
Hondata S300 ECU
USDM Type R transmission - bought it brand new from Honda (has roughly 3k miles)
Clutch Masters Stage 4 Clutch
Clutch Masters Stage 4 Flywheel
Vibrant 4-2-1 Header
SS Hayame Exhaust
AEM Hybrid Cold Air Intake w/ Bypass Valve
AEM Fuel Rail
AEM Fuel Pressure Regulator
Skunk 2 Intake Manifold
Skunk 2 68mm Throttle Body
Skunk 2 Valve Cover Bolts
NGK BKR7E (6097) Spark Plugs (extra plugs included with sale)
NGK Plug Wires
Mugen Oil Cap
Mugen Radiator Cap (bnib Cusco Rad Cap included with sale)
Mishimoto Radiator and FAL Fan
Cusco Oil Tank Catch Can
Samco Hoses
Quaife Quick Steer Rack (not installed, but included with sale. New OEM steering rack is installed)
PasswordJDM Hood Dampers
PasswordJDM Carbon Fiber Plug Cover
PasswordJDM Magnetic Drain Plugs: Engine/ Transmission
Golden Eagle Dip Stick
Internally the car is stock
Suspension:
Tein Flex Coilovers
Tein EDFC (Electronic Dampening Force Controller) - 16 settings from hard to soft
Skunk 2 Front Camber Arms w/ new ball joint
Skunk 2 Rear Camber Arms w/ new ball joint
Skunk 2 Lower Control Arms
Skunk 2 Tie Down Bar
Password JDM 3Pt Strut Tower Bar
Password JDM Front Cross member and Radiator Support
All basic bushings replaced with stiffer polyurethane ones
Wheels/Brakes:
Enkei PF01 15x8 Toyo R1R - brand new
Enkei RPF1 15x7 Kuhmo Semi Slicks - few track days and autox
Skunk 2 Extended Wheel Studs
Wilwood 4 Piston Front; ITR rear calipers (rear disc brake conversion)
Stainless Steel Brake Lines
Interior:
Sparco EVO II's
Sparco Seat Mounts and Rails
G Force 5pt. Harnesses
Sparco Suede Steering Wheel
NRG Quick Release Hub
AIM Dash -- digital gauge cluster
ITR Shifter
Password JDM Shift Linkage and Bushings
Skunk 2 Shift Knob
Password JDM Carbon Fiber Fuel Pump Cover
JDM Radio Block-Off Plate
JDM Climate Control
Battery Relocated to trunk in a Taylor box w/ a kill switch
Aluminum Door Panels -- painted black
SCCA 6pt. Cage done by Nate Dog Creations - $8k cage (need to see it to believe it)
Interior repainted black
Exterior:
Nighthawk Black Pearl Paint
JDM EF8 Front End
JDM EF8 Front Lip
JDM EF8 Tail Lights
JDM EF8 DOHC VTEC Decal
JDM EF8 Si R Badge
Carbon Fiber sunroof insert
Carbon Fiber mirrors -- VIS Racing
Carbon Fiber Hood-VIS Racing
Carbon Fiber Hatch-VIS Racing
Carbon Fiber Air Ducts-Password JDM
Aero Catch Hood Pins
Rolled Fenders
Tinted Windows 20% - Done by Shades of Gray
Antenna shaved
Extra Parts included with sale:
All receipts from over the years
Fire extinguisher w/ sparco mount
LEXAN Windows (rear hatch & rear quarter panel; bnib)
G-Force Window Net
G-Force Interior Net (bnib)
ProCar Innovations Rear Spoiler
Carbon Fiber Canards
Front Splitter (for a USDM front bumper, but I'm sure you can make it fit with some fab work on the JDM front bumper)
New Car cover and car cover bag
Rear bumper painted to match (incase you want to do away with the wing and the cut bumper)
original hatch
Still for sale!!! Will accept some trades + cash!
  • 1 month later...
