lonestarrpm Posted September 6, 2016 Share Posted September 6, 2016 Trailex Aluminum Trailer 20 feet 84180 forsale I found the trailer I thought was going to be perfect for me and had it shipped. When it arrived -- it was too narrow for my RSR. The RSR is extremely wide at 78", and the trailer inside wall to wall is 80". (I had been told it was wider) These were designed with the 911 in mind, just not one quite as wide as mine. Not too many 911's run on 14" slicks. The trailer is a 99, but in very good condition. 4 new wheels and tires plus 5th wheel spare in perfect condition. The trailer is also very well equipped. 1000W Inverter, Air Conditioner, 2 Odyssey batteries, Diamond plate, floor, walls, insulated, Double Awnings, side window, side drivers side swing out doors Double Tire Rack, Spare Tire Dual Pull down storage compartments Foldable built in diamond plate work bench. 11' aluminum ramps 6' interior head room Passed inspection with flying colors. If you are looking for an lightweight enclosed trailer at less than 1/2 the cost of new, this is the one for you. Can easily be pulled behind an SUV. Weight about 1800# according to Trailex. $12K Located in Austin. Mike [email protected] Quote Link to comment Share on other sites More sharing options...
lonestarrpm Posted November 15, 2016 Author Share Posted November 15, 2016 SOLD!!! Trailex Aluminum Trailer 20 feet 84180 forsale I found the trailer I thought was going to be perfect for me and had it shipped. When it arrived -- it was too narrow for my RSR. The RSR is extremely wide at 78", and the trailer inside wall to wall is 80". (I had been told it was wider) These were designed with the 911 in mind, just not one quite as wide as mine. Not too many 911's run on 14" slicks. The trailer is a 99, but in very good condition. 4 new wheels and tires plus 5th wheel spare in perfect condition. The trailer is also very well equipped. 1000W Inverter, Air Conditioner, 2 Odyssey batteries, Diamond plate, floor, walls, insulated, Double Awnings, side window, side drivers side swing out doors Double Tire Rack, Spare Tire Dual Pull down storage compartments Foldable built in diamond plate work bench. 11' aluminum ramps 6' interior head room Passed inspection with flying colors. If you are looking for an lightweight enclosed trailer at less than 1/2 the cost of new, this is the one for you. Can easily be pulled behind an SUV. Weight about 1800# according to Trailex. $12K Located in Austin. Mike [email protected] Quote Link to comment Share on other sites More sharing options...
