FS: 2011 Camaro Trans Am/ GTS PWC $25k
chewy8000
This car was really nice before it got wrecked at Mid Ohio and could be easily swapped into a new tub.
All of the parts to rebuild this car are here including body work spares, engines and transmissions. Just needs a new tub, cage and labor to swap everything over. We have decided to cut our losses instead of trying to raise funding for a rebuild or part everything out... List of parts below with quantities.
(1) Original vehicle Title available(4) Z28 Fender Flares
(1) Z28 OEM Front Splitter(1) CF/FBGLS Hood – Yellow(
(2) Steel Doors – Yellow(2) OEM Front Fenders Right(2) OEM Front Fenders Left
(1) Front ZL1 front Bumper assembly
(1) Steel Rear Deck Lid OEM
(1) Z28 Rear Bumper Upper Fascia
(1) Z28 Rear Bumper Lower Fascia
(1) Z28 Front Bumper Fascia w Splitter
(2) CF Brake Duct Adapters
(2) Z28 Rocker Panels
(1) LS3 race Motor w/ new OEM headers
(1) LS3 crate Motor w/ new aftermarket headers
(4) Tremec T6060 OEM Trans
(8) Rear Axle Half Shafts
(2) Hood Pins
(1) Tilton Bearing Seal Kit
(2) Stop Tech Front Rotors
(1) Aeromotive Fuel Reg Seal Kit
(2) Energy Suspension Sway Bar Bushings
(1) Peterson Oil Filter
(1) Wix Fuel Filter
(1) Throttle Pedal Extension
(1) Belt Tensioner and used belt
(2) Oil Pump Belts
(1) Serpentine Beltrn(Too many) Misc. springs for old shocks
(9) OEM Headlights
(1) Big Black Box Bin filled with MIsc. parts
(2) Used rear brake calipers and lines
(1) used clutch and flywheel assembly
(2) Mock headlight CF with stickers
(4) New Hoosier rain tires from 8/15/16 unused
(8) One heat cycle Hoosier race slicks
(1) Fuel safe fuel cell with bulkhead
(11) BBS race wheels
(1) PWC spec carbon race wing
(1) Borla race exhaust
(1) 60mm Katech restrictor for trans am
(4) Penske race dampers
(1) Pratt Miller rear suspension relocation system
(1) Pratt Miller Front camber plate & Engine brace system
(1) Fire system
(4) Lexan windows
(1) AIM MXL Pista data system and tach
(1) 3.91 OS Geiken Differential
(1) 3.45 Auburn Differential
(1) Schroth belts
