02Roushstage3 Posted September 11, 2016 Posted September 11, 2016 selling all the suspension from my car. mostly everything is still on the car and wont be available until the end of September after NASA Nationals. We can work out a deposit or something in the meantime though. or just do 1st dibs if you are serious about something. please ask if you have questions about anything and i can probably send some pics email me at [email protected] or call/text 716-359-2821. im located in Buffalo NY Thanks, Mike (4) Pirelli slicks 2 heat cycles 305/660/18 450 (4) Pirelli slicks 2 heat cycles 305/680/18 450 (4) Black Enkei RPF1 wheels 18x10.5 +15 1250 (4)Black Enkei RPF1 wheels 18x10.5 +15 with Pirelli slicks 1800 (4)Silver Enkei RPF1 wheels 18x10.5 +15 1250 (2)Silver Enkei RPF1 wheels 18x9.5 +45 600 (4) Hankook C91 6 heat cycles 350 (4) Continental Slicks 4 heat cycles 400 (4) Pirelli 305 slicks 3 Heat cycles 425 (4) Continental Rain Tires 1 heat cycle 400 (4) Ambit RE02 18x10.5 +15 wheels(only mounted tires-never used)- Matte Black 600 04 IRS- full MM bushing kit The mods are as follows Maximum motorsports Delrin rear upper & lower control arm bushings,MM IRS subframe bushing,MM IRS adjustable tie-end kit,MM rear swaybar bushings & end link kit,MM urethane differential mounts,MM low profile IRS subframe bolts,Upper IRS subframe brackets,BF IRS brace,Cut factory springs. Looking to get 1,500.00 out of it picked up. I will not ship as I do not have time to mess with it. 25000 miles 1450 25mm sway bar 55 28mm sway bar 55 22mm sway bar 55 99-04 Maximum motorsports front control arms-Delrin-non offset 325 99-04 Maximum motorsports front control arms- forward offset- Delrin 325 SOLD 99-04 Maximum motorsports caster/camber plates 130 Maximum motorsports rear spherical shock mounts for MM or Bilstien shocks 130 Koni (Griggs) Rear coilovers 500 Koni DA front Coilovers 600 Koni Rear DA coilovers used for 1 track day 750 Maximum motorsports HD torque arm needs new brackets from Maximum Motorsports 450 Griggs Watts link? 0 Stoptech ST-40 Calipers comes with 2 used sets of Hawk DTC-60 pads and another set 850 Built 8.8 Rear end detroit true-trac, 31 spline axles,arp wheel studs, 1350 pinion yoke- 6 track days 800 Roush rear caliper brackets would perfer to sell with rear end 100 roush alcon 13" vented rear rotors would perfer to sell with rear end 200 MOTIVE 31 spline axles would perfer to sell with rear end 150 detroit truetrac diff would perfer to sell with rear end 325 ROUSH alcon front calipers Brand new in box with pads-no brackets 700 kenny brown brake ducts 120 1.5" wheel spacers 35 Maximum motorsports Sway bar relocation kit 40 1st dibs to crewwolfy 9/8 Maximum motorsports low profile control arm bolts 20 Roush Rear valances 150 Original Cobra R trunk and wing 300 1' wheel spacers 35 1" wheel spacers 35 Maximum motorsports Cobra strut bar 120 Maximum motorsports MM3 IRS bilstein shocks brand new still in box 300 Maximum motorsports IRS coilover kit brand new still in box 275 Maximum motorsports IRS Diff brace brand new still in box 210 2" wheel spacers 55 Maximum motorsports Rear lower shock mount brand new still in box 40 howe steering column mount brand new still in box 40 98 Mustang spindles-not drilled 150 bumpsteer kit 45 1st dibs to crewwolfy 9/8 JAZ 1 gallon overflow tank 45 Quote
