naknak Posted September 16, 2016 Posted September 16, 2016 I never though the day would come but it's time to put my beloved Avus Blue on Black E36 M3 track car up for sale. I bought the car stock in 2004 with its current clean title(always has been a California car, NO rust) and slowly built it up to where it is today. She has gone from stock to show to Auto-X to HPDE and has always been garaged. It has only been used for the occasional HPDE recently (2 events per year) but is completely setup for BMWCCA IP/NASA GTS 2-3/SCCA STU racing minus a fire system. The oil has been changed after every 2 events and brake fluid changed after every event. The car has been serviced or worked on by some of the best shops in California (TC Design, Performance Technic, Edge Motorsports) and has recently been corner balanced with driver and race inspected. Almost every sensor and gasket has been replaced within the last year and there are no leaks. She is currently listed as Non-Op and the price is $26,000 OBO. I'm sure I am missing some of the mods/spare parts but if you are interested please email me at [email protected]. Engine - New E36 M3 3.0L Crate Engine with 35k Miles (178k on chassis) - All New Censors as of Aug 2015 - New Valve Cover Gasket July 2015 - Every power steering component changed June 2014 - Schrick Race Cams - Custom Turbo Hoses Intake with Heat Shield - BMW 540i HFM - Bimmerworld 3.5 Intake Elbow - Dinan Big Bore Throttle Body - Evo Sport Underdrive Pulleys - Bimmerworld Oil Pan Baffle - Welded Oil Pump Nut - 24 lb. Injectors - Turner Motorsports Tuning Cooling - BMW E46 M3 Oil Filter Housing - Bimmerworld Oil Diverter Valve - Bimmerworld Oil Distribution Block - IE Aluminum Radiator - Stewart Performance Water Pump - Aluminum Thermostat Housing - Setrab Series 6, 16 Row Oil Cooler - Spal 30101516 16" Straight Blade Low Profile Fan - Samco Silicon Hoses Interior - Momo Steering Wheel - NRG Quick Release - NRG Short Hub - Bimmerworld Center Dash Plate - Auto Meter Oil Temp, Water Temp, Oil Pressure, Diff Temp Gauges - Pyrotect Driver Side Window Net - Bimmerworld Aluminum Door Panels - Bimmerworld Solid Race Shifter - Sparco Circuit Pro Seat - Sparco Side Mounts - Spaco Slider - VAC Floor Mounts - UUC Stainless Steel Shift Knob - Teamtech Mesh Right Net - Schroth Profi III 6 Point Harness with Pads - Allview Rearview Mirror - 8 Point IP/GTS3 Legal DOM Tubing Cage - Bimmerworld SFI-Spec Hi Energy Cage Padding - Sunroof Delete - TC Design Sunroof Plates - UUC Brake Pedals - Hard Motorsports Cutoff Switch and Plate (uninstalled) - VAC Handheld Fire Extinguisher - Bimmerworld Duel Fuel Pump Kit Aero - UUC Carbon Fiber Dive Planes - Brooks Motorsports Carbon Fiber Race Wing - Turner Motorsports Headlight Duct - Gutted Passenger Headlight Blank - Max Velocity Evo III Race Splitter Suspension - Ground Control DA Coilovers Rebuilt 9/9/16 (0 miles) - Ground Control 900/900 Springs - Ground Control Adjustable Front Endlinks - Ground Control Articulating Rear Spring Perch/Weight Jack - Ground Control Spherical Rear Shock Mounts - Vorshlag Camber Plates - BMW X-Brace - New BMW Z3 Steering Rack - Bimmerworld Front Subframe Reinforcement Kit - Bimmerworld Solid Engine/Tranny Mounts - Dinan Front Strut Brace - Front/Rear Sub Frame/Chassis Reinforcement Kit - Rear Shock Tower Reinforcement Plates - Rear Trailing Arm Pocket Reinforcement Kit - AKG Race RTABs Brakes - Stoptech 4-Piston Front Big Brake kit with Hawk HT-10 Pads - Rear HP+ Pads - Bimmerworld Brake Cooling Kit - Bimmerworld Stainless Steel Brake Lines Wheels - Kosei K1s 17x8.5 with NT-01 255/45/17 - Bimmerworld Stud Package - 5mm Front Spacer Diff/Transmission - Diffsonline 3.73 Variable Ramp Triple Clutch Diff LSD - Rouge Engineering Diff Cover - Bimmerworld Solid Diff Mounts - E36 M3 ZF 5sp - JB Flywheel Exhaust - Custom Titanium 3.5 Inch Full Header Back Exhaust with V-Bands For A Straight Pipe/Catalytic Converter - Magnaflow Single Outlet Muffler Other/Spares - Custom Aluminum Lightweight Battery Holder - Spare Trunk - Spare Rear Bumper - TC Design Front Tow Hook - VIS Carbon Fiber hood Quote
