FS: 1984 NASA GTI Cup Car
Posted (edited)
This is a well sorted race car built by Erickson Motorsports in Ca. The car also has a NASA Log book from when the builder/racer raced the car in Ca. I only ran the car in HPDEs. There also a ton of spares including an extra set of wheels. The car does have a VIN but no title. The car should fit in NASA's PTE class.
Suspension:
Neuspeed 25mm Front Sway Bar
Neuspeed 28mm Rear Sway Bar
Bilstein Shocks
Neuspeed Upper Tie Bar
Neuspeed Lower Tie Bar
Neuspeed Solid Upper Strut Bearings
New Dimensions Front and Rear Poly Motor Mount Bushings
New Dimensions Steering Rack Bushings
New Dimensions A Arm Bushings
Eurosport 4-point lower X Brace
Scirocco front 10.1 rotors and brake calipers.
Motor:
Techtonics Tuning 1.8 l 8 Valve Inline 4 (The motor was originally built by TT).
Ported and polished head by Autotech with Autotech's 286 cam stock size valves, HD valve springs and Titanium retainers.
Autotech Tri-Y header with header brace and header flange.
Autotech Shock Therapy plug wires.
Mk-II throttle body.
Scientific Rabbit Stage 3 Performance Intake Manifold.
Schrick oil pan.
Oettinger valve cover.
New Dimensions oil Cooler.
Griffin Radiator.
Techtonics 2-3/4” Exhaust pipe with Borla muffler.
Stock fuel tank and pump installed in 2012.
Transmission:
Close Ratio 020 5 speed trans. with a Wavetrac LSD and ARP bolt set.
Interior:
6 Pt Cage (The cage is numbered. I'll post an image as soon as I can.)
Spacrco Racing seat for Driver
Stock seat for passenger
Carbon Fiber dash with VDO gauges
Weight with full tank and driver.
LF 680 722 RF
2174 LB
LR 438 334 RR
$5,750 obo.
[email protected]
Videos and photos of the car.
http://gticup.blogspot.com
0dI1oifWO_o
As you can see, it runs strong.
db6cHGSWehY
1OcotQup2jk
-ICF_Hrsb4M
y1IeqbBda9c
  • 2 weeks later...
  • 2 weeks later...
  • 2 weeks later...
I love this. It's a throw back; a piece of NASA history.
Might be helpful to list the car in a current class. Try using the PT rules to get a classification.
Based on stated mods, high PTF to low PTE best I can tell.
Perhaps the OP will take the time to work up a points sheet. It is a pretty car...
Thanks, I remember running it through the classification a few years ago and it fit in PTE. It would have to be ran on a dyno to get power/weight ratio.
Think it's putting more than 138 to the ground? If not, I'd not sweat the dyno expense.
The dyno sheet that came with the car when I bought it stated upper 90s. I did headwork, cam, header and intake manifold. It might be close but I'm guessing 115-125.
  • 3 weeks later...
