rodtino Posted November 28, 2016 Share Posted November 28, 2016 2004 BIW Mustang Cobra 2004 Terminator Aluminator Engine (see below for more detail on the engine) Full MM Suspension front and rear Offset Control Arms Tie-Rod Ends MM K-Member Strut Tower Brace (not installed) Coil Over Kits Custom Swaybar endlinks in rear Torsen T2R diff Trans and Diff Coolers Willwood Big Brake LT Headers American Muscle FR500 17x10 front and 17x11 rear rims Cool Suit Carbon Hood, doors and Trunk Lid Remote Oil Filer Expansion Tanks for Supercharger Canton 7qt. Oil Pan Road Race Seat Engine: Block:…………….….Ford Aluminum 4.6L Crankshaft:……….Ford stock stroke Pistons: ……………Diamond W/Molly side coat, Ceramic top coat and Tool Steel Pins Rods:…………….….Oliver Pro Light Bearings:…………..Clevite Head Gasket:…....Cometic Hardware:……......ARP Bolts and Studs Camshafts:……....Comp Cams Valve Springs:.….Comp Cams Valves:………….....Ferrea SS Oil Pump:……......Melling Fuel Rails:……..….Aeromotive (Regulator, Fittings) Throttle Body:…..Dragon polished Blower:……………..M112 W/Stiegmeier Stage 4 Water Pump:…....Edelbrock Gaskets: …………..Fel-Pro Oil Pan:…………....Canton W/Oil Shield Balancer:…………..Innovators West Flywheel:……….….Ram Light Weight Steel Clutch:……………...Ram Twin Disc Other:……………….Balanced Assembly, Blueprinted ProWeld Socket head Bolt Kits, Inter-Cooler Coolant Hose System and Breather System Engine tuned to 109 race fuel. Car come with an untapped drum of 109 race fuel and race radios $22,500 Quote Link to comment Share on other sites More sharing options...
