Audi Motorsport B7 A4 FIA/SCCA Welded Pinned Caged
Audi Motorsport B7 A4 Chassis FIA/SCCA welded pinned caged by Audi MS UK
For More Images - Please Contact Us!
Pace Amerian 24ft enclosed duel axel trailer with load leveling, ramp door, 12v/110v lighting - OPTIONAL (NOT INCLUDED IN PRICE)
1 new Mahle 1.8T engine with intake/exhaust manifold, modified exhaust manifold and assorted sensors
1 used Mahle 1.8T engine with intake/exhaust manifold, turbo and assorted sensors
Two race transmissions with assorted spare couplers
1 OE tranmission 01E-301-211-C
1 rear differential 4.11:1
1 fender 8E0-821-106-F
1 1K0-145-803-A
B7 Driver's Headlight
B7 Passenger Headlight
Pair of B7 Headlights
Filebox w/ Old Race Data
Assorted braided hose
4 clutch master cylinders
1 brake master cylinder
2 front stoptech calipers
2 rear stoptech calipers
Assorted caliper rebuild parts
5 axles
Assorted axle parts
2 power steering pumps
4 flow valves
1 "Adventure Cam" camera
Assorted mics and camera cables
Assorted camera clamps/fittings
Aerolatch hood pin latch kit
Energy suspension ARB bushings/mounts
Motor mount jigs
Assorted hardware/metal stock
Fuel pump w/ broken housing
Assorted fuel lines/filters
Control module w/ switch
Battery
Assorted transmission parts
Clutch slave cylinder
Assorted hardware
2 IHI turbochargers
1 IHI turbine housing
2 grill inserts 8E0-807-681-J
2 grill inserts 8E0-807-682-J
4 throttle cables
1 mirror
4 aluminum brake ducts
1 subframe attachment 8E0-599-287 K/L
1 8E0-807-272-A
1 8E0-807-271-A
2 pull cables w/ red handles
1 Setrab oil cooler 50-619-7612
1 set brake pads
4 "wero" mounts w/ replacement bushings
Assorted electronics and cables
2 bushing mounts
1 jig
4 pre-cut metal pieces for jig
C-dash display w/ cables for harness
Oil temp. sensor
Assorted switches/lights
Assorted brackets/hardware for harness
3 brake brackets
3 tie rod ends
2 ball joints
2 AD racing master cylinders 6P2623-91PRJ11S
4 Tilton racing bolt kits 95-032
Assorted heim joints, boots and hardware
Assorted S.S. line
Misc. bridge tubes
1 1K0-145-840-F
1 078-133-610-C
2 06F-129-627-G
1 1K0-145-770-K
1 1K0-145-770-P
Assorted charge pipes/silicone lines
1 06D-103-215
1 06D-145-778-C
1 8E0-145-790-G
1 8E0-145-737-Q
Assorted Hardware
1 8E0-133-356-D
2 B7 A4 Sidemount intercoolers
C-Dash wiring harness
1 C-Dash display
Assorted machined aluminum spacers
8 steering rack boots 7820-040-766
Holder assembly
1 power steering pump 1J0-422-154-J
2 rear toe links 8E0-501-529-K
2 upper suspension mounts 8E0-412-383-C
2 mounts 8E0-807-788-B
2 mounts 8E0-807-787-B
8 mounts 8E0-807-381-C
2 reflectors 8E0-945-071
2 reflectors 8E0-945-072
1 fitting 078-137-534-C
Bolts 4B3-121-200
1 mount 8E0-955-276-E
1 mount 8E0-955-775-E
4 M1.25x125 bumper bolts
3 pullies 038-145-255-B
1 2K0-821-439
1 8L4-831-720
1 box of self tapping screws
1 bumper insert 8E0-807-077-B
1 bumper insert 8E0-807-076-B
2 8E0-853-588
2 8E0-853-587
4 8E0-853-379
1 small damper 8E5-827-552-J
2 Cobalt brake pad sets CRB.XR3.DO44
2 Cobalt brake pad sets CRB.XR3.ALM4
2 Tilton racing clutches 66.002HORA/66-002U66
2 Performance Friction Brakes Brake pad sets 63.650.0961
2 used steering racks
1 left front upright
1 front upright
1 front upright
1 front upright
1 right front upright
1 front upright
1 front girll
1 right headlight
1 left headlight
1 left headlight
1 left headlight
1 pair of B6 taillights
Tire rack with 6 tires and four wheels with tires mounted
Assorted race radio gear
1 foam pad
1 intake box
3 mounts 8D0-399-107-S
2 mounts 8D0-399-108-AN
2 mounts 8E0-199-305-A
12 bushings
4 torque mounts
3 "wevo" mounts
2 Moroso radiator caps
2 DMC catch cans
1 electric fan
2 silicone hoses
1 aluminum pipe
5 aluminum intake pipes
1 8J0-853-651-A Y9B
Assorted OE and custom motor mounts
Modified upper race suspension mounts
Assorted bushing
Assorted OE taillight,covers,bulbs
Assorted shifter/linkage parts
Electronics
Wiring
Assorted gaskets/SS braided line
Jack
Jack
Assorted residential electrical components
Rain suits/wet gear
camera components
ITG air filter JC60/73
Assorted Alcon race caliper components
2 front fender inserts 8E0-857-507-B GRU
2 front fender inserts 8E0-857-508-B GRU
1 set brake pads Performance Friction Brakes 63.660.0372
Assorted heim joints and spacers
Carbon Fiber kit
1 steering wheel
2 443-498-201-B
Clutch discs and bearings
Assorted oil coolers w/ pumps and oil lines
1 C-Dash w/ harness
Rubber hose with fittings
Assorted rubber hoses
Braided S.S. lines
1 electric fan
Assorted aero. and body parts
1 roll plastic sheathing
6 STaSIS logo plates and front grill insert
2 3" brake duct hoses
2 silicone hoses
1 8E0-839-912-M
1 8E0-837-911-L
1 8E0-837-912-L
1 8E0-837-911-M
1 8E0-837-912-M
13 damaged wheels
1 wheel w/ tire mounted
Assorted wiring, switches
Assorted suspension fittings, AIM system
Assorted springs
Assorted springs
Assorted springs
3 turbochargers
Assorted hoses and fittings
Roll cage jigs
Rotors
pads
Assorted tubing accessories
Sway bars
Steering Racks
Race chiller cooler with plumbing
Cooler with plumbing
Steering rack
Oil cooler
Intercooler
Catch can
Misc. jigs
2 Mahle fuel filers
Carbon fiber air box
Aluminum piping
Catch can
Cooler suit
Assorted race team shirts
16 coil packs 8E0-905-115-E S3
3 Continental belts - 6K1120
1 timing belt 06B-109-119-A
Assorted wastegate springs
1 wastegate actuator
2 camshafts
4 gaskets 058-253-039-L
3 throttle bodies 06A-133-063-G
4 throttle body gaskets
Assorted fittings
1 dipstick
1 pulley 078-105-251-L
6 steering rack boots
Hard line 8E0-317-821-AA
Hard line 4F0-317-817-A
Hard line 4F0-317-818-A
Hard line 8E0-317-822-A
2 bearings 01E-311-117
2 splined belts
4 plates 0A2-141-719
2 metal gaskets
5 bushings 4D0-411-327-J SB
1 belt cover 06B-109-108-B
1 oil housing 06A-115-417
8 A4 injectors
2 8D0-798-151
1 gasket 078 121-043-A
2 N-905-144-01
1 Tilton bolt pack 95-032
1 06D-103-121-B
Assorted hardware
5 assorted turbo inlet fittings
Assorted gaskets/bearings
3 wheel hubs 4B0-407-613-B
7 aftermarket bearings
2 Mann filter HU71916X
2 filters 06D-115-562
1 077-198-563
1 02E-305-051-C
12 016-409-399-B
2 01E-311-207
Solar panel and trailer lights
Fender 8E0-821-106-F
2 ITG air filters
Assorted aluminum piping
1 hardware box
4 doors
4 splitters
2 B6 doors
3 rear doors
1 left rear B7 door
1 right rear B7 door
3 front B7 doors
1 pair of B7 side skirts
1 left rear quarter panel 8E5-809-839-A
1 front grill insert
5 rear valences
1 driveshaft
3 plastic oil drain pans
1 roll of wire mesh
5 aluminum bumpers 8E0-807-313-L
1 078-103-604-H
2 boxed radiators
5 lead weights
3 core supports 8E0-805-594-E
2 front lower bumper covers
1 left front fender
1 dented right rear B7 door
1 trunk lid
3 windshields
1 carbon fiber center console
1 front intercooler
1 bucket of "racing lubricant"
1 upper door frame
1 green throttle cable
1 side skirt
4 door mouldings
1 left rear interior quarter panel 8E5-809-045-EB
1 subframe 8E0-803-104-F
1 side member 8E0-803-103-F
1 side member 8E0-803-104-F
1 B7 rear bumper chrome trim piece
1 set of door mouldings
Trim 8E5-853-346-E
2 trim pieces 8E5-853-701-GRU
Trim 8E0-853-7680A
Trim 8E0-853-767-A-2ZZ
Trim 8E0-853-766-A
Trim 8E0-853-765-A
2 trim pieces 8E5-853-709-A
Trim 8E0-837-479-E
2 trim pieces 8E0-853-986-B-7DL
Trim 8E5-853-710-A
3" hose
1 STaSIS front grill insert 8E0-807-287-D
4 foam wraps
1 differential cover 01R-525-137-C
Assorted silicone hose
1 GKN boot
1 metal brace 8E0-802-531
1 metal brace 8K0-505-219-C
1 metal brace 8K0-505-220-C
Carbon fiber mesh
1 bin of stickers
1 bin of large vinyls
2 sheets of aluminum
1 clear plastic sheet
