mysticz Posted January 16, 2017 Share Posted January 16, 2017 I'm selling a 1992 mazda mx3 track car. It is on a non op and I don't have the title for it, for track use only. It was a track car for a few years until 2008, the drive train was pulled because the previous owner was going to have different cams put in the motor. It sat from 2009 until now. I put the motor and transmission back in it. I started the motor without the axles in and the transmission spider gears found there way out so it needs a new transmission (oops) It has a japan spec KLZE 2.5 v6 motor, ground control adjustable coil overs, dynamic racing wheels, steel braided brake lines, upgraded mass airflow sensor with apexi controller, aluminum flywheel. make offer and email for more pictures. Thank you. Car is located in sacramento california. I can't seem to upload pictures, email and I will send some to you. [email protected] from when it was running. Quote Link to comment Share on other sites More sharing options...
