[email protected] Posted January 25, 2017 Share Posted January 25, 2017 CONTACT (985)507-4007 2003 BMW M3 (E46) $ 39,000 Car: -Purchased car in April 2016 (it was traded in at New Orleans Porsche dealership) -Came with full service records since new and it was in almost perfect condition -All original with 155,000 babied highway miles with NO rear subframe damage -All work was professionally performed at Pellegrini performance group in Madisonville LA -I have all receipts and most items were purchased from Bimmerworld and ECS and Turner Motorsports -Car is in Immaculate showroom condition Recently purchased / installed (ALL NEW PARTS) -Auto Blip (intelligent downshifts) RPM REVSynch. -Auto power full bolt-on roll cage # 83904 (have full cage but only installed rear) -(2) Auto power harness (2) PC 106: PRO-CAM Driver restraint System -New Sparco 320MM racing steering wheel with NRG hub and Quick release -New Bimmerworld Brake cooling Kit with 3” NACA ABS plastic duct vent -(2) New Billet Aluminum seat floor mounts -Rouge Octaane Short shift Kit E46 M3 CNC -(2) OMP HTE-R racing seats -(2) OMP seat sliders Mount set -(2) OMP steel seat side mount set tall starndard adjustment -Schroth eye bolt reinforcement plate with 22mm bolts -New OME Drive shaft -Powerflex rear Subframe front and rear bushings (PFR5-4610BX2 / PFR5-4611BX2) -E46 Sub-frame / Chassis Reinforcement Kit -Stainless Steel Rear shock Tower Reinforcement plates -Ground control front and rear swaybar E46 M3 -(4) insulated E46 @WD [email protected] Stainless Steel Brake lines kit -(4) aftermarket front and rear rotors -(2) rebuilt OEM calipers -(2) Carbo Tech Racing Brake pads XP16 fronts -(2) Carbo Tech Racing Brake pads XP 12 rear -Bimmerworld Solid Brake guide Kit -BImmerworld (ISC N1) coilovers (have 2 sets of springs soft and very hard) -Powerflex Rear Trailing Arm Bushing Kit (RTAB) -Original set of wheels with new 235x35x19 Proxes R888 -New set of Apex ARC 8 square set 18x9.5 with new Poxes R888 -Shift Rod Joint, circlip, shifter arm bushing, locking pin, dowel pin -BImmerworld 12.5 mm wheel spacers rear -Premium Rce Bulletnose wheel studs – 82mm -Silver Lug Nut – m12, 17mm -NRG Carbon Fiber A690 – 69” rear wing -DD racing Rear Cornering Strut Bar Brace -Stainless Steel 2.5 “ Catback axle back exhaust with 2.75” tips -Race spec - Corner balanced and aligned -Change motor oil, transmission fluids, brake fluids, and rear differential fluids -ECS Heavy Duty Aluminum coolant bleeder screw -ECS Constant pressure valve -ECS Valve cover gasket set -Cooling system Refresh Kit with pump -Valve adjustment -Oil Pan Center cover Gasket -ECS Mechanical A/C Belt tensioner -ECS Hadraulic Belt Tensioner and roller -a/c and alternator/water p[ump belts -ECS idle pulley -Oil Filter Housing Gasket -Expansion Tank Hose -ECS cooling system Refresh Kit -ECS steering coupler -ECS power steering reservoir -Spark plugs (DCPR8KP/7415) -Turner Motorsports solid motor and transmission mounts -Turner Motorsports S54 Power pulley Kit -(2) Racing Lower control arm Bushings -Graphics and racing numbers -M3 matts -M3 Hub caps -Windshield fluid reservoir -10 MM ESC spacersfront -Turner motorsports carbon fiber front chin splitter FOR PICTURES CLICK ON LINK http://showroom.windingroad.com/listings/product/2845/ Quote Link to comment Share on other sites More sharing options...
