be4real Posted February 10, 2017 Share Posted February 10, 2017 $16,450.00 all spares included. For sale is a 944 built and maintained by Motor Werks Racing near Atlanta, GA. Highlights of the overall build include the lightened bodywork, custom 2.5L engine, full weld-in cage, big brake kit, and MCS damper & coilover system. Even driven by this knucklehead, the car was able to achieve multiple podium finishes and a NASA GTS1 track record at Road Atlanta (1:45.855 back in 2013). I’ve only driven the car in HPDEs lately, four HPDE events in 2015 and five in 2016, for ~90 hours on the engine since race-spec build. MWR replaced the rod bearings in Sep. 2015. Or maybe you're thinking about GTS3/4? With the MCS’s, cage, and big brake kit already in place, this 944 could also be a good candidate for a 1.8t conversion similar to what others have already installed. Engine: 2.5L Motor Werks Racing engine (naturally aspirated) Balanced Injectors Camshaft with adjustable gear Custom Head – CC & matched ported Custom Ported Intake manifold Baffled oil pan Ceramic coated pistons & rod bearings & main bearings High Flow Fuel Pump Four into one header with V-Band full flow exhaust, etc. Aluminum Flywheel Sach Motorsports Clutch Kit Oil Cooler Suspension: Custom MCS remote canister damper & coilover system, custom front swaybar, adj. rear swaybar, Delrin bushings 944 Ball joint kit - Performance / Track upgrade 17 mm Long Pin Torsion bars removed & all Delrin suspension bushings Adjustable camber plates Bump steer kit, tie rod end (adjustable) Modified spring plates Body: Many custom & fiberglass pieces, eg: fiberglass 944 hood, Spoiler, fenders, bumpers, lightweight mirrors, etc.; Sunroof Delete; Lexan windshield, rear hatch and side windows w/Z-clips; Power Options Delete; Height Adjustable Pedals Weight ~2,485 lbs Brakes: Wilwood 4-piston Big Brake Kit, front brake ducts Gearbox: Short Stack gear box with short 5th gear Limited-slip differential Wheels & Tires: 8x Color Matched Phone Dial Wheels - 4x 15" and 4x 16" 16” Tires – 2x 225/50 R16 Hankook Ventus and 2x 245/40 R16 Hankook Ventus 15” Tires – 4x 225/50 R15 Hoosier R6 Safety & Convenience: Full Weld in Cage with welded seat mount OMP HTE Race Seat OMP-HA772 OMP Passenger Race Seat (not currently installed - located in spares) Custom 2G "Cool Suit" Box - relocated to rear SPA 3.5 Fire Suppression System TraqMate w/input box, power to GoPro 2 box mounted on roll bar Driver - Schroth Profi II 6 point harness - HANS- Black Passenger 6 Point Harness Removable Momo Steering Wheel & Hub Adaptor Custom Kill switch, Tow Hook, Schroth window net Helmet hook, Steering wheel hook 2x ECUs - 1x "Race," 1x "Performance" Spares: Misc. cooling hoses Brake pads Misc. fuse relays, etc. Fresh brake fluid Engine oil Car cover Professionally maintained, to recently include: (12/16): winterization incl. add fuel stabilizer, and put in climate-controlled storage, etc. (11/16): R/R rear brake pads; replace pads w/performance set; bleed brakes & clutch; tension belts; clean air filter; replace rotor cap; replace MAF sensor (09/16): Gear lube service; R/R front brake lines; bleed brakes and install stainless steel brake line; replace front control arms and hub assemblies. ...and much more. Quote Link to comment Share on other sites More sharing options...
be4real Posted May 2, 2017 Author Share Posted May 2, 2017 SOLD Quote Link to comment Share on other sites More sharing options...
