Stowell Posted March 11, 2017 Posted March 11, 2017 SOLD For Sale: Showroom Spec Miata (SSM) Car: 1992 Mazda Miata MX-5 1.6L I've had this car since October 2013 and raced it the last 3 years, mostly at Summit Point. Looking to move on to a faster car and need to sell this car first. Lots of upgrades last year and it's ready to race. Current log book for NASA and can also race in STL or PTE. Work done last year: -Kirkey 71500 Aluminum Containment Seat 16" Wide -OMP 6-Point FIA Harness Expires After 2021 -Racequip Window Net -Rebuilt Transmission -Act 4-Puck Sprung Clutch and Pressure Plate -New Master and Slave Clutch Cylinder -New Rain Tires, Toyo RA-1 on Team Dynamincs Wheels ET25 -New Hubs Front and Rear with Enduro Studs -Rebuilt Brakes -New Battery -New Header -New Brake Pads and Rotors, Hawk DTC-60 and DTC-30 Mods: -Piper Motorsports Roll Cage with NASCAR Door Bars Both Sides -New Crate Motor in 2012 -Spec Miata Suspension and Roll Bars -Spec Miata Chassis Braces -'99 Torsen Differential Conversion -Jongbloed Wheels ET25 -Sparco Steering Wheel with NRG Quick Release -Simpson Center Net -Mazda Hardtop -Kill Switch and Fire Extinguisher -Mazdaspeed Spec Exhaust -Radiator Warehouse Aluminum Radiator -Mazda Hardtop -Depowered Steering Rack -Passenger Side Window Vent and Removable Window -70 Pounds of Ballast Bolted to Passenger Floor -Car Cover -Factory Service Manual and Spec Miata Counstructor's Manual Spares: -Set of Toyo RA-1 Dry Tires -Passenger Side Fender -New DTC-60 Front Pads, Many Used Pads, and Set of Used Brake Rotors -Set of Hubs, Rear Uprights -Throttle Body -ECU -AFM -Intake Trailer: -16' Wood Deck Car Trailer with 4' Beaver Tail -Dual 3,500 lb Axles -Electric Brakes -Steel Ramps -2,000 lb Winch -Spare Tire -Battery Break Away Quote
