xspeedracer Posted May 27, 2017 Share Posted May 27, 2017 Front Koni adjustable sport struts modified with adjustable height collars with 7w shock oil, 400 lbs/in 2B springs and 2B upper camberplate assembly Rear Koni Sport shocks modified with 7w shock oil, 300 lbs/in 2B springs with adjustable lower perch spring seat and delrin upper spring locator. This kit is adjustable with a floor jack 3" up or down car will go down to 2" ground clearance and does not require tools other than a 5mm Allen to lock the collars in place. This is a track setup kit ok for Street use, but harsh 30k on this kit no issues. suspension kit Camber plates Quote Link to comment Share on other sites More sharing options...
