TCB Honda Posted June 12, 2017 Share Posted June 12, 2017 For Sale: Mustang MD-AWD-150 SE 1,200 / 2,000-hp peak measurement capacity (2WD/AWD) 625-hp peak absorption (one eddy current) Purchased New in May 2012. 190 Total Hours Usage to Date. Maintained properly. Rollers in good condition Includes The Following. 1 MD-PAU: Hi Speed Eddy Current Absorber PAU W/harness 1 MD-LC: Closed Loop Load Cell W/harness 1 MD-SPEED-60; 60 Pulse per Revolution Vehicle Speed Sensor W/harness 1 MD-COVERS: Pit Covers / Top Plates 1 MD-CAL: Calibration Kit 1 Mechanically Linked Roller System (to prevent drive train damage from occuring) 1 Manual AWD/2WD Engage-Disengage on/off coupler** 1 MD-CART: Roll-around Shop Cabinet (completely integrated W/power supply) 1 MD-PC: Computer with upgraded 27-inch Flat Panel LCD Monitor 1 MD-PDSOFT: PowerDyne Pro Dyno Control and Data Acquisition Software Suite ( 0-5 volt Analog Input Channels ( 0-5 volt Analog Output Channels 1 MD-AFR: Air to Fuel Ratio Meter - Dual Sensors 1 MD-PRESSB: Pressure Sensor (vac-85psi) for measuring boost on turbos 1 MD-IWS: Weather Station integrated with Dynamometer 1 MD-SMART: Smartach RPM System with Inductive Pick-up 1 MD-TS1: TS:1 Coil Driver RPM Pick up (for use with MD-SMART) 1 MD-RAMP16A : 16 Foot Aluminum Ramp Set 1 MD-APD : Manual Axle Pull Down 1 MD-AG : Above ground Mounting Kit with Tie Down Truss 1 Lifetime warranty on frame 1 Cooling Fan. 1 36" Additional Monitor for Customer Display *Notes - Front and Rear Drive belts replaced, Speed Sensor Replaced. Front Retarder cover professionally modified with hinges to allow quick decoupling. Computer upgraded to SSD Drive. Contact: [email protected] Quote Link to comment Share on other sites More sharing options...
