Legends427 Posted June 13, 2017 Share Posted June 13, 2017 Hank Scott motor and carbs in car, w/Spare Dennis Shaw motor, both in good condition w/low leakdown numbers. Both motors have top-end oilers, shimmed oil pumps, pinned cams, and adjustable cam gears. 2 Spare Carb Sets w/Redline Jet Kits. Setrab #634 large oil cooler, w/second cooler for top end, and SS braided AN hoses. Borla Stainless Header w/both Muffled and Open Collectors. Fuel Safe steel FIA fuel cell. Halon fire system w/engine and cockpit nozzles. Aluminum Spindles. Carbotech Brakes. Billet axles. Spare welded axles. Double spring clutch setup. Spare clutch plates and spring. Spare APE billet clutch assy. with coil spring PP and spare basket. Auto Meter 5” 10,000rpm tach, Pro-Comp Oil Press and Oil Temp gauges w/AN hose. VDO Cylinder Head Temp gauge. LED Shift Light w/adj RPM switch. LED Rain/Brake Lights. All legal frame gussets added. Recently rebuilt steering rack. Bilstein Shocks. Spare Springs. 2 Sets of Silver Bassett Wheels/Tires. Spare Ign. Coil Set. Spare Ignition Pickup. 3 Spare Bumpers. Spare Brake Master Cylinder. Spare Calipers. Spare Upper and Lower Control Arms. Spare Suspension links, Heim joints, and Hardware. Spare New Lexan Windshield. Spare Engine Side Cover. Spare Oil Pan. Spare Pinned Cams. Spare Crankshaft. Spare Connecting Rods. Blueprinted Rearend Housing with Spooled 2.50 Gear in car. Extra Gears: 3.30 Spooled. 3.42 Welded. 3.58 Welded. New 2.92 Richmond Gear w/Bearings and Shims and new Spool, uninstalled. Quick Jack. Car never had a hard hit, but due to some minor damage I had the frame completely rebuilt and trued on a frame jig. Never hit since rebuild, and car is straighter than new. Body is original with original gelcoat, never painted or repaired. Meticulously maintained by OCD owner/driver. Maintenance and setup records included. Hasn't been raced in a while, so harness and tires are out of date. I'm sure there's more stuff I've forgotten. Everything devoted to the Legends car goes. Pictures available, and any specific questions, just ask. Quote Link to comment Share on other sites More sharing options...
