CMC#64 Posted September 27, 2005 Share Posted September 27, 2005 Registrated for HPDE at ButtonWillow on Oct 8th & 9th, will I receive an e-mail with the schedule and my car number?? Thanks Quote Link to comment Share on other sites More sharing options...
FocusTed Posted September 27, 2005 Share Posted September 27, 2005 Registrated for HPDE at ButtonWillow on Oct 8th & 9th, will I receive an e-mail with the schedule and my car number?? Thanks You will get a schedule for the event a couple days before it. The car number will be the number you selected first unless you're told different. But, keep in mind if you're running in Group 4, The TT numbers are assigned and you will not be able to use those numbers. You might want to look to see if you have a conflict. http://socal.nasa-tt.com/Numbers.html Quote Link to comment Share on other sites More sharing options...
CMC#64 Posted September 27, 2005 Author Share Posted September 27, 2005 I'm running in group 1 Quote Link to comment Share on other sites More sharing options...
FocusTed Posted September 27, 2005 Share Posted September 27, 2005 I'm running in group 1 Okay good. Then it will be your first choice unless you're told different. Quote Link to comment Share on other sites More sharing options...
tapaule Posted September 29, 2005 Share Posted September 29, 2005 You will recieve an email with the schedule and a run down of the event. It is also posted online a few days before the event, if you don't get one, someone usually links to it on the forums. The numbers aren't that important as they are easily changed trackside (just bring some blue painters tape and you'll be okay). What's more important is making sure your car is ready (fresh brake fluid, check and see if the pads are okay, etc). There's a good bit of info here on the NASA HPDE page (http://www.nasaproracing.com/hpde/index.html). I'd sugggest takign this weekend (Oct 1st and 2nd) to look over your car with this HPDE Tech form in hand (http://www.nasaproracing.com/images/rules-forms/form_hpde_tech.pdf) so you'll know what to look at. Nothing worse that getting to the track and not passing tech! I think the event is filling up quickly, so you'd better register soon. Hope to see you there!! Quote Link to comment Share on other sites More sharing options...
CMC#64 Posted September 29, 2005 Author Share Posted September 29, 2005 You will recieve an email with the schedule and a run down of the event. It is also posted online a few days before the event, if you don't get one, someone usually links to it on the forums. The numbers aren't that important as they are easily changed trackside (just bring some blue painters tape and you'll be okay). What's more important is making sure your car is ready (fresh brake fluid, check and see if the pads are okay, etc). There's a good bit of info here on the NASA HPDE page (http://www.nasaproracing.com/hpde/index.html). I'd sugggest takign this weekend (Oct 1st and 2nd) to look over your car with this HPDE Tech form in hand (http://www.nasaproracing.com/images/rules-forms/form_hpde_tech.pdf) so you'll know what to look at. Nothing worse that getting to the track and not passing tech! Been registered since mid August! Got burnt waiting to the last minute for Sears/Infenion... Got the tech done in August also.. I'm getting the rotors turned this weekend and picking up a set of Performance Friction pads for it... I think the event is filling up quickly, so you'd better register soon. Hope to see you there!! Quote Link to comment Share on other sites More sharing options...
