bpanther Posted November 23, 2017 Posted November 23, 2017 NASA Prototype Rules Change Requests – Summary Approved for 2018 1. Mandate bump stops front and rear ~$75 Approved, reliability. Front bump stops are now allowed to help keep nose/splitter from bottoming. To eliminate the need to test for different tracks and conditions, the spec stops will be mandated on all cars. 6. Allow side window vents ~ $250 Approved, driver comfort. Allows better venting and ability for “point-bys”. 7. Increase minimum weight Approved, parity – Changed to 1775lbs. Reduces the number of competitors who are unable to meet the minimum weight. 8. Allow air intake scoop ~$500 Approved. Will improve top speed performance. 13. Allow modification of canopy to make removal easier Approved, serviceability. NASA tech bulletin to be created for details. 14. Allow any manufacturer for master cylinder (maintain same size) ~ $250 Approved, reliability. Any brand with similar list price (<$150ea) is permitted. 15. Open fuel pump to any manufacturer ~ $150 to $250 Approved, reliability Permit Bosch 044, AEM 50-1005 or Holly 12-935. 17. Fix front spring rate at 600lbs Approved, cost containment. Following the intended path of decreasing complexity of suspension setup and testing. 18. Fix rear spring rates at 2 choices (1400/1600) Approved, cost containment. Following the intended path of decreasing complexity of suspension setup and testing. 19. Allow wheel speed sensors on all corners ~ $75 per corner Approved, driver development. Allow for driver development and aid in setting bias bar. 20. Specify (or leave open) where extra splitter support cables may attach. Approved, reliability. NASA tech bulletin to be created for clarification. 21. Allow addition of Elan oil cooler kit. ~ $600 Approved, reliability. Help with cooling during high temperature and/or high elevation events. Elan to create tech bulletin. Not Approved for 2018 2. Allow any size master cylinder ~ $250 We need data showing changing master size would help bring the balance bar ratio more neutral. 3. Allow 1800lbs rear springs ~ $150 Class focus is to limit # of choices, no proven data showing need for stiffer springs than 1600 4. Allow any rear suspension pickup points - no material costs Class focus is to limit amount of adjustments to caster/camber/toe/rake. 5. Replace water temp sensor with head temp sensor ~ $1500 No significant need provided with request. Rule will be rewritten to allow coolant pressure sensor or extra temp sensor to be hooked to AiM. 9. Allow front high downforce splitter ~ $7500 Not within cost containment intention of class 10. Allow front splitter ramps ~$1000 Not within cost containment intention of class 11. Allow rear diffuser (see #9) Not within cost containment intention of class 12. Allow alternate wheels Not approved per agreement with mfg and supplier 16. Allow RARB kit ~$1800 Not within cost containment intention of class Quote
Francis Hu Posted November 24, 2017 Posted November 24, 2017 I need ideas to add 50 lbs of ballast. The two lugs on the frame just in front of the seat tub does not have much room to add a lot of weights. Quote
C.Plavan Posted November 24, 2017 Posted November 24, 2017 I need ideas to add 50 lbs of ballast. The two lugs on the frame just in front of the seat tub does not have much room to add a lot of weights. I have used the bosses for the heel stop in front of pedals also. The weight made a great heel stop also. Dave put lead shot mounted under his seat also. Quote
bpanther Posted November 24, 2017 Author Posted November 24, 2017 Yep. I took lead shot and poured it into the two cavities under the seat. Then adhesive and rivets to secure flat aluminum sheet over the top. The two bosses in front of the seat are good up to 65lbs per Elan. Quote
C.Plavan Posted November 24, 2017 Posted November 24, 2017 https://www.speedwaymotors.com/Speedway-50-Lb-Lead-Ballast-Weight,2164.html Drill two holes and boom! Just double check length. I did this for 35 pound weights when I ran ST2. Quote
rikgray Posted January 31, 2018 Posted January 31, 2018 (edited) Now I have an excuse to eat well; to make spec weight. Edited February 12, 2018 by Guest Quote
rikgray Posted January 31, 2018 Posted January 31, 2018 (edited) 6. Allow side window vents ~ $250 Approved, driver comfort. Allows better venting and ability for “point-bys”. Does anybody have a picture of a side window vent? Edited February 12, 2018 by Guest Quote
rikgray Posted January 31, 2018 Posted January 31, 2018 generally, an excellent evolution of class rules Quote
